NEO 75w90 RHD or MTF
Old Jul 10, 2010 | 11:53 PM
Spoolin's Avatar
Default NEO 75w90 RHD or MTF
I was doing some research and noticed this NEO lube. Has anyone looked into the NEO 75w90 RHD or their MTF? NASCAR, CART and IRL use it.
I wonder if the NEO 75w90 RHD would be ok to run in our trans? I've heard of many people with DSM, Nissan and Mazda synchro trans running it and they love it. Many tested it up against the Redline stuff thats comparable and they say the NEO kills it.
Here is a link to both of the lubes.
NEO 75w90 RHD
http://www.bakerprecision.com/neocirc.htm
NEO MTF
http://www.bakerprecision.com/mtf.htm
Old Jun 8, 2012 | 08:49 PM
Dipstick's Avatar
NEO 75w90 RHD
NEO MTF
I just started running NEO 75w90 RHD (Racing Heavy Duty)...a friend who works with IRL motors says they use this...it's the only gear oil that withstands the temps.
If you use the HONDA bulb pump to put it in, it is THICK - feels 2x thicker than the Mobil 1 75w90.
Old Jun 9, 2012 | 02:40 AM
sata3000's Avatar
I just ordered some. Ill give it a shot and see how it does. I dont think any kind of fluid is going to help my glass diff from blowing.
Old Jun 9, 2012 | 10:41 AM
Spoolin's Avatar
I've been running the RHD in my stock trans and it shifts like butter. I'm also making near 800 whp and it seems to be helping with shock load and heat as the trans is still holding up so far. We'll see how long it lasts with this lube.
Old Feb 27, 2019 | 02:01 PM
2rbolag's Avatar
Excuse the thread revival but the RHD is a GL-5, not intended for our transmissions. It is although excellent for the diff. The MTF is GL-4 and suited for our gearboxes. NEO are an excellent lubricants. Cannot go wrong
Old Feb 27, 2019 | 04:42 PM
Spoolin's Avatar
I ended up going with the RHD in the trans and it worked great.
Old Mar 1, 2019 | 02:37 PM
2rbolag's Avatar
did it held up together to your power level? I’m around 7xx on the stock transmission. Wondering if the rhd is gl4/gl5 compatible
Old Mar 1, 2019 | 03:51 PM
Spoolin's Avatar
I like to believe it helped, since I had no issues using it at upwards of 800 whp. The stock trans isn't in the car any longer.
s2kt3
Oct 5, 2012 11:25 AM
irev9k
Oct 21, 2008 06:05 AM
Rick Hesel
Aug 9, 2008 02:55 PM
Jimbo3277
Jun 1, 2008 06:29 AM
ashamouel
24
Aug 8, 2007 03:16 PM
