New build
^ Dude your 15 years old and drive and old Supra. Don't come on an s2000 forum talking like you know what you are talking about and do not come on here arguing with friends of mine. The wide band will be moved to where spooling suggested. I trust his judgement way more. IF AMS thinks it can be moved they can move it in a matter of minutes. Plus moving it will allow me to bring the car to get finished without having to plug the 02 bung or have exhaust fumes burn up the engine bay.
I also believe Sam "carguy" had it in the same place spoolin.
Originally Posted by Spoolin,Aug 17 2009, 07:01 AM
Seth has the same kit as me and the first bung is about 20 inches from the turbo and is where the wideband should go as i mentioned and the best place for an accurate reading. The second lower bung he can just put the stock narrow band o2 in there to close the hole. The stock narrow band o2 is not used on the AEM so it doesnt matter whether it is plugged in or not. I dont have any stock o2 sensors plugged in to my setup nor on the car.
Hmmm...i never did like those end of exhaust o2 probes. At least the one on a dynojet i used to use a few years ago. Its readings were off from my wideband. At the dynojet i go to now, we unplug my o2 and plug it directly into the dynojet software. I trust that way much better. If you're using Chris at AMS to tune still, they may have a better end of pipe o2 probe than the one at the dyno i used to use. You should ask Chris if you can plug your o2 sensor into their software like i do if he doesnt think the end pipe probe is as good.
Bung is plugged. Now for some reason the car won't start. It was starting fine yesterday and the other day once I finished everything. Not sure what the problem is. Seems like a dead battery. I have my charger on it now. Once it starts, I'll post a video.
It's weird though that the battery was fine yesterday. It def seems like the battery doesn't have enough juice. I left the battery on a battery tender for a few hours and I actually got the car to crank and then nothing. Before it was just nothing but dim lights. I'll leave the battery tender on for the night.
Would it be a fuse if the lights were very dim with no cranking when trying to start? After a charger was on for a while it cranked a couple of times and then completely died with no lights. I've had my battery tender on since last night. I'm guessing the battery isn't holding a charge.
