New build
Old Aug 16, 2009 | 08:36 AM
  #71
s2000isu's Avatar
buy a plug for the o2 bung you can buy them at any performance shop. I have bought them from www.extremepsi.com
Old Aug 16, 2009 | 10:41 AM
  #72
carman594's Avatar
Yea, keep the wideband atleast 36 inches from the turbo because they're more sensitive to the heat. They make plugs or you can get it welded shut.
Old Aug 16, 2009 | 07:06 PM
  #73
sbrodacz's Avatar
Banned
I jsut want a quick fix for the mean time. I have an appointment on wen to get the exhaust and charge pipes done. If I have to order the plug I won't get it in time.
Old Aug 16, 2009 | 07:50 PM
  #74
Spoolin's Avatar
Originally Posted by sbrodacz,Aug 16 2009, 10:37 AM
The only problems I am having right now is the down pipe has a 02 bung welded in right at the top of the pipe. There is also one at the end of the down pipe. I put the wide band at the end of the down pipe. Whenever I start the car exhaust fumes come from the top of the down pipe through the 02 bung. It's starting to burn the air conditioning lines. Is there an easy quick solution? The car sounds like an absolute monster when started. She's still idling like perfect. I wanted to take a video clip and post it, but I do not want to let the car run for more then a couple of seconds if that with that 02 bung open.
Seth, the wideband o2 should be put at the bung closest to the turbo for optimal readings and you can just plug the stock secondary o2 in the lower bung for now if you like. Or just leave it that way and it won't hurt anything.
Old Aug 16, 2009 | 08:13 PM
  #75
Spoolin's Avatar
Also Seth, I priced out everything that will be needed to make a dual pump setup and it will run about $1150. That includes 1 more Walbro pump $85, fuel pressure regulator $140, fuel filter $110, fuel rail $175, dual hanger $400 (unless you can come up with another way to do it with the stocker or something else), -10 and -8 hoses and fittings $250. I think I am going to go ahead and get the Full Blown setup.
Old Aug 16, 2009 | 08:43 PM
  #76
sbrodacz's Avatar
Banned
That's pretty much the same price as full blown, isn't it? Looks like the route I'll be taking.
Old Aug 16, 2009 | 10:54 PM
  #77
Spoolin's Avatar
You are correct. Itll just be best to go with the full blown setup since everything is in the kit and complete with instructions. Itll run us about $1150 taking one of the pumps out of the original price.
Old Aug 17, 2009 | 06:18 AM
  #78
carman594's Avatar
Wrong. The stock O2 sensor should be closest to the turbo and the wideband should be MINIMUM 18 inches away from the turbo. The wideband is more sensitive to heat and could result in burning up from the heat of the turbo. Don't believe me? Read this: http://wbo2.com/lsu/position.htm You can Google, "Wideband sensor placement" and see what I mean.
Old Aug 17, 2009 | 07:01 AM
  #79
Spoolin's Avatar
Seth has the same kit as me and the first bung is about 20 inches from the turbo and is where the wideband should go as i mentioned and the best place for an accurate reading. The second lower bung he can just put the stock narrow band o2 in there to close the hole. The stock narrow band o2 is not used on the AEM so it doesnt matter whether it is plugged in or not. I dont have any stock o2 sensors plugged in to my setup nor on the car.
Old Aug 17, 2009 | 07:28 AM
  #80
carman594's Avatar
Yes, well Seth currently is running on his old tune, which was why I put it at the 2nd bung. He is most likely running rich due to lack of a new tune which can possibly burn up the wideband O2 sensor. When he's getting his tune, he should put the wideband at the bung closer to the turbo. Seth, leave the wideband where I put it until you get your tune.
