New Endyn Manifold..
Old Jan 20, 2014 | 01:38 PM
  #61
Urge's Avatar
Sponsor
Originally Posted by godmachine
I would be really interested to see how my kinsler manifold would stack up to this one . Also link to more in depth info on your turbo heads if you wouldn't mind
What details are you looking for on turbo headwork?
We had a customer gain 60 hp and spool up 500 rpm faster. Same psi, only change was headwork.
Flow gains.. http://urgedesigns.com/boost-velocit...ck-graph1.html
HP gains... http://urgedesigns.com/endyn-head-work-turbo.html
All the work and parts are listed on our site.
http://urgedesigns.com/velocity.html
Patrick
__________________
Old Feb 5, 2014 | 05:25 PM
  #62
Urge's Avatar
Sponsor
Originally Posted by wadzii
Please make sure you guys mill the flange flat. EVERY SINGLE fabricated intake manifold I have delt with was warped all to hell.
one very popular manifold required milling 0.080" off the flange to get it flat.
It seems like as soon as you cut the plenum off the #1 runner moves in toward the #2 runner and pulls that end of the flange up.
Also.. bragging about out flowing some 50mm itb's isnt much to brag out.
This piece of crap I made flowed more than 50mm itb's on the flow bench...
It really sucks that there isnt enough room in an s2000 to make a proper intake manifold. We've been playing with long runner manifolds alot this year and the results are amazing. just gota figure out how to fit a long runner and big enough plenum in an s2000.
Just curious on how test flow the manifolds? Any pictures of the set-up?
Also, we don't take a lot of material out of the manifold very subtle how we shape the flow so we can raise air velocity too. We can certainly over port everything for flow sake, but torque & response die.
__________________
Old Feb 6, 2014 | 05:21 AM
  #63
wadzii's Avatar
Banned
RLZ does all my cylinder head work and flow testing. He has a flowbench.. its the big flow bench that actually works properly for automotive applications. Most cylinder head guys have the cheap motorcycle oriented flow bench which doesn't work well on cylinder heads that flow over 300cfm.
We dont do a lot of flowing intake manifolds, the dyno and track is a far better measure of performance than a flow bench when it comes to intake manifolds. Flow benches dont generate waves in the intake like a motor does. 50mm itb's are barely big enough for a stock f20c, much less anything you want to make some real power on. The stock s2000 runners are good enough to pretty easily make 275hp, the wall of the plenum being less than an inch off the opening to the runners is the problem..
People put way too much thought into velocity in an intake manifold and a port. The velocity is always the highest at the valve, changing it a little here or there in the intake manifold will have no real effect on getting the car down/around the track. Will it show a gain on the flowbench.. yeah probably, but does it matter when the thing is running.. probably not.
Old Feb 6, 2014 | 06:26 AM
  #64
Urge's Avatar
Sponsor
How does he flow the manifold, does he simply mount a runner to the flow bench?
Yes we understand about pulse waves in the intake manifold and what RPMs and how much air. All of our ITBs lengths are adjusted based upon the customers desired Redline.
As far as ITB throttles, you can't compare one to the other as all the throttles are different distances away from the port. Making a general statement of 50mm is too small isn't accurate with out knowing the rest of the dimensions. We had a set of 45mm dyno 330 crank but they were 1" from the port. The Jenvey based throttles (hayward & toda) are typically ~3.5" away from the port and kindlers are set at 5.5" away from the port. So based on runner taper, you can not directly compare one throttle size to the other. In fact our 52mm ITBs flowed the same as 60mm Kinslers up to .550 valve lift. 60mm should flow way more, but if it is 60mm 5.5" away and mine are 52mm 3" away then the size difference isn't that much.
We strongly believe in air velocity so we will have to respectfully disagree. You have to keep velocity up everywhere. In the port, in the runners, in the plenum. If air velocity has issues anywhere in the intake system, it will slow velocity at the valve. Here are a few examples..
When we dyno'd our 52mm ITBs vs the 60mm Kinslers we had more torque throughout despite both flowing the same.
We just rebuilt a low compression gt motor for a customer and gained 10 ft lbs of torque and 15 top end HP by moving to a 68mm TB down from a 74 as the low velocity in the plenum was stalling the runners and thus the velocity at the valve.
In our opinion air velocity gets the car down a track. Endyn has had too many successful racing customers to prove other wise.
I appreciate the comments and responses.
__________________
Old Feb 6, 2014 | 06:32 AM
  #65
beaudin223's Avatar
i do think its a good product with nice R&D but its still to much $$$ , i think for 400-450hp on stock motor turbo this intake dont worth it , if you want more than 700 800hp i think this manifold is the way to go , its overkill for a N/A settup or low boosted engine , and if somebody dont like this welding just buy a wrinkle black paint and everything look better after
Old Feb 6, 2014 | 01:47 PM
  #66
Urge's Avatar
Sponsor
At 400-450 hp, our manifold should provide 30 hp gains.. Some would think it is worth it.
__________________
Old Feb 6, 2014 | 02:50 PM
  #67
AE85's Avatar
The relevance is really highlighted for track guys (like myself), if I can make the same power with less boost (which the manifold in theory allows), then the engine runs cooler, I dont have to worry about overheating "as much" or long term stress on the engine "as much". 30HP may be 2-3psi, which is substantial in a racers mind. It may even allow me to run less expensive fuel, all those kinds of things come into play.
Old May 1, 2014 | 07:25 AM
  #68
liquid_helix136's Avatar
^^ Thats a good point, especially with the heat problems with turbos on these cars, the more you can do to control heat and keep it at the same power level, the better, and a lot of people may consider that worth the coin.
BalladeSports
Apr 8, 2014 10:27 AM
JohnnyP912
Dec 1, 2009 10:48 AM
codeman
Apr 16, 2009 05:32 PM
Adampops
Apr 18, 2007 07:30 AM
Pappy
20
May 18, 2004 07:19 AM
