New setup, new #'s (548/413)
Changed a few things up this summer, primarily switching to an URGE "boost velocity" built head and pulling my Fullblown dual in-tank pump setup in favor of the new Science of Speed dual pump surge tank.
548hp / 413tq @ 13.6psi on E85
Pretty happy with the power for such a low boost level....hopefully that will help with the longevity of my motor
Here's my Setup:
Motor:
URGE built bottom end
darton sleeves
lightened shaved crank
billet I-beam rods w/7/16" bolts
wiseco 10:1 pistons w/ceramic coated tops
ported oil pump
fluidampr crank pulley
URGE built head w/inconel exhaust valves
AP1 intake cam / AP2 exhaust cam
ARP studs
Turbo kit:
full race pro street (ramhorn)
Garrett GTX 3576R w/ 1.06 A/R housing
Fuel system:
Walbro 450 E85 pump in tank
SOS dual pump surge tank w/AEM 320 E85 pumps
SOS pump wiring kit & plumbing kit
-8AN feed line / -6AN return
Fullblown fuel rail
FID 1200 cc injectors
Tuned on Hondata KPro
Timing is around 14 degrees
Injector duty cycle is at 72%
VTEC crossover was set to ~4k rpms
Rev limiter set to 8600
We tried turning up the boost to 16psi. We did gain a bit of power (extra 20hp / 10tq in the midrange), but the graph started getting pretty choppy on the topend. I didn't think the little bit of power was worth the extra wear and tear.
Disclaimer:
This is not a drag or track car and will never see the strip or track. I wanted a fun street car with quick spool and a meaty powerband
Scott-
Here's my Setup:
Motor:
darton sleeves
ported oil pump
ARP studs
Turbo kit:
Fuel system:
Fullblown fuel rail
Disclaimer:
Scott-
No plans for pump gas atm, I planned/built it to mainly run E85 from here on out....luckily an E85 station opened 2 miles from my house
Awesome numbers...but are you saying the turbo was pretty much out of steam at 1 bar? Great setup...1.06 AR on T4 Twin Scroll isn't shit really, bigger is better...love the powerband.
What was your base FP???
I think you would max out the turbo around 20-22psi...in the 600whp range...goes to show how absolutely awesome the F20 motor is...it take 30psi to make that power on a 4G63.
