Newly boosted - CEL question
Old Oct 7, 2014 | 11:04 PM
Speed2Kill's Avatar
Default Newly boosted - CEL question
Hey folks,
I recently installed KW SC kit (new version). Overall great however I've started to have an intermittent problem.
My cell will flash for a few seconds for no particular reason before going out. If I pull the codes with the Torque app it gives me "pending fault" codes for misfires on multiple cylinders. All cylinders are affected though not all at the same time. I will also occasionally get a full CEL with multiple cylinder misfire codes. The car drives completely fine. I wouldn't think there was anything wrong except for the silly light. There is no shudder no loss of power and nothing in particular causes it to happen.
Also I noticed my dipstick is popping up occasionally without leaking any oil. I assume increased crank case pressure and plan to vent with Supra PCV valve mod.
Any ideas on the "misfires", just ghosts in the machine or something more ominous?
Thanks much!
Old Oct 8, 2014 | 04:07 AM
VTEC2000's Avatar
Did you install new or regap your plugs when you installed the sc?
Old Oct 8, 2014 | 09:35 AM
Speed2Kill's Avatar
All new plugs
Old Oct 8, 2014 | 11:03 AM
Chance S2K's Avatar
Originally Posted by Speed2Kill
All new plugs
Did you get them gapped appropriately? You normally want to lower the gap to ~.025ish, but it varies depending on your fueling situation and your power output. Most gaps on spark plugs from the factory are higher than this.
Also, definitely work on getting a catch can installed to relieve some of that crankcase pressure. You don't want all that blowby recirculating into your intake either.
Old Oct 8, 2014 | 11:36 AM
JUSTINTHECOASTIE's Avatar
OP, call and let John know. I'm sure he can figure this out
maranelloboy05
May 15, 2013 07:03 PM
Slmd2K
Oct 30, 2010 11:53 AM
CasanovaJr
Mar 9, 2010 10:26 AM
leroyneal
May 25, 2009 12:18 PM
shinigamiz
Jul 11, 2008 08:45 PM
