NGK 7548 - BR9EYA
whats the reasoning behind that? there are tons of high hp cars that run the cbr coils which are 1/10th the price of aem's coils and are also an inductive coil which from what ive gathered is more beneficial than the cdi aem pencil coil
Originally Posted by wadzii,Jan 14 2010, 07:25 AM
if the idle gets messed up then the plug is probably too cold and fouling itself out.
how much power are you making and what gas are you using?
Originally Posted by Deception,Jan 14 2010, 03:05 PM
407hp, 93 octane
I used to run the iridium 2668's but they are so much more expensive than the copper 7173's. When I called Ya at IP, he said to just run copper plugs and he said the resistor 4776 plug (I think they are a resistor plug) is what they run but I cant find them anywhere. He said they used to use the nonresistor 7173 plug but have switched to the 4776 plug and its better.
When I did switch to the 7173's, I did notice that I had more misfiring but never saw this with the iridium 2668's I used to run. I just dont want to spend $7 a plug when, if I can find the right resistor #8 plug, will work just as well for $3 a plug.
Will a #8 plug be fine for 600+ whp or would it be better to go with a #9 plug when running e85?
I havent seen enough big hp e85 cars to help there, colder wont ever blow your motor up, so i usually start too cold. If the plug is too hot you will melt things.
I get the 2668's for about $6 bux a piece and they generally last a really long time. I have to change the copper plugs with my oil.
