NGK BKR7E vs. BKR7E-E
Old Jul 16, 2009 | 03:15 PM
CKit's Avatar
Default NGK BKR7E vs. BKR7E-E
We previously ran BKR7E (#6097) and they work well on our high boost Comptech setup. Went to order some more plugs and mistakenly picked up BKR7E-E (#4776) instead. I've heard that Inline Pro recommends the BKR7E-E plugs, but I'm not finding what the difference between the E and the non-E versions are.
Does anyone know? Is it the pre-gap vs. the non pre-gapped? Or is there a functional difference?
Old Jul 16, 2009 | 04:13 PM
s2000Junky's Avatar
E as in Electrode? Do they look different visually at all? Someone had a NGK spec sheet floating around recently with many of these plugs specs related to the numbers, heat ranges, materials used etc. Be interested to see if these two plugs were listed on that sheet. Might tell you.
Old Jul 16, 2009 | 04:16 PM
busterpit23's Avatar
I have a sheet give me a sec and I will post it up. I run the BKR7E-E on my setup.
Old Jul 16, 2009 | 04:19 PM
Here you go, its just a difference in the electrode and insulation size.
Old Jul 16, 2009 | 04:34 PM
s2000Junky's Avatar
^^^Right on there you go Ckit
Old Jul 16, 2009 | 04:35 PM
fltsfshr's Avatar
sorry I can't read it, what's the difference in the electrode?
fltsfshr
Old Jul 16, 2009 | 04:39 PM
s2000Junky's Avatar
[QUOTE=CKit,Jul 16 2009, 03:15 PM] We previously ran BKR7E (#6097) and they work well on our high boost Comptech setup.
Old Jul 16, 2009 | 06:21 PM
CKit's Avatar
Thanks, busterpit!
S2000Junky, it does seem strange that the BKR7E's are technically stock-ish but that was suggested as the resistor counterpart of the 7173's back in the day. It is interesting that the BKR7E-E's are the plug of choice for at least one of InlinePro's setup. We haven't had any problems with lean state, but our tune is pretty rich and we've lowered compression.
fltsfshr, click on the picture... then click on it again to see it full size.
Old Jul 16, 2009 | 08:43 PM
juntuned's Avatar
BKR7E-11 (5791) is gapped at .044 (oem)
BKR7E (4644) previously known as 6097 is gapped at .035
BKR7E-E (4776) is gapped at .032
Not sure what the other differences are...
BKR8EIX (2668) is gapped at .032
IFR8H-11 (5068) is gapped at .044
Information is from ngk.com
Old Jul 16, 2009 | 09:24 PM
s2000Junky's Avatar
Originally Posted by CKit,Jul 16 2009, 06:21 PM
Thanks, busterpit!
Interesting, yeah i'm using the (2668)BRK8ix something or other, its the platinum/iridium tipped resistor plug that is one step colder. I tried the 7173's and though they were nice and cheap, I had some interference issues with my radar detector it seemed. Other then that they seemed to run issue free, but after reading some problematic stories I decided to switch to the 2668 alternative that most seem to be going to. They seem to last longer then the copper 7173's as well.
