Nitrous Air/Fuel
Old Feb 12, 2010 | 05:22 PM
hariku821's Avatar
Default Nitrous Air/Fuel
I have a Dyno tune lean cut off switch connected to the stock narrow band. It recomends that you set it at .8v and im wondering if its safe to go lower than that. I ask because the switch is shutting me down. so it must be dipping below .8 ,not sure how far though.
I have found a post on a 350z forum that shows a list of volts converted to A/F. Would this list work for our cars as well?
To read afr from volts
Volts===========AFR
0 ===== 10
0.0625 ===== 10.1
0.125 ===== 10.2
0.1875 ===== 10.3
0.25 ===== 10.4
0.3125 ===== 10.5
0.375 ===== 10.6
0.4375 ===== 10.7
0.5 ===== 10.8
0.5625 ===== 10.9
0.625 ===== 11
0.6875 ===== 11.1
0.75 ===== 11.2
0.8125 ===== 11.3
0.875 ===== 11.4
0.9375 ===== 11.5
1 ===== 11.6
1.0625 ===== 11.7
1.125 ===== 11.8
1.1875 ===== 11.9
1.25 ===== 12
1.3125 ===== 12.1
1.375 ===== 12.2
1.4375 ===== 12.3
1.5 ===== 12.4
1.5625 ===== 12.5
1.625 ===== 12.6
1.6875 ===== 12.7
1.75 ===== 12.8
1.8125 ===== 12.9
1.875 ===== 13
1.9375 ===== 13.1
2 ===== 13.2
2.0625 ===== 13.3
2.125 ===== 13.4
2.1875 ===== 13.5
2.25 ===== 13.6
2.3125 ===== 13.7
2.375 ===== 13.8
2.4375 ===== 13.9
2.5 ===== 14
2.5625 ===== 14.1
2.625 ===== 14.2
2.6875 ===== 14.3
2.75 ===== 14.4
2.8125 ===== 14.5
2.875 ===== 14.6
2.9375 ===== 14.7
3 ===== 14.8
3.0625 ===== 14.9
3.125 ===== 15
3.1875 ===== 15.1
3.25 ===== 15.2
3.3125 ===== 15.3
3.375 ===== 15.4
3.4375 ===== 15.5
3.5 ===== 15.6
3.5625 ===== 15.7
3.625 ===== 15.8
3.6875 ===== 15.9
3.75 ===== 16
3.8125 ===== 16.1
3.875 ===== 16.2
3.9375 ===== 16.3
4 ===== 16.4
4.0625 ===== 16.5
4.125 ===== 16.6
4.1875 ===== 16.7
4.25 ===== 16.8
4.3125 ===== 16.9
4.375 ===== 17
4.4375 ===== 17.1
4.5 ===== 17.2
4.5625 ===== 17.3
4.625 ===== 17.4
4.6875 ===== 17.5
4.75 ===== 17.6
4.8125 ===== 17.7
4.875 ===== 17.8
4.9375 ===== 17.9
5 ===== 18
Old Feb 12, 2010 | 06:59 PM
D1sclaimer's Avatar
Why not just buy a wideband.
Your engine is worth the 200 dollars for an Innovate LC-1.
Old Feb 12, 2010 | 07:04 PM
hariku821's Avatar
Isnt it basically the same thing if you convert the volts?
Old Feb 12, 2010 | 07:30 PM
camuman's Avatar
NO. the resolution of a narrow band pales in comparison to the resolution of a wide band. 0-1v doing what a 0-5 volt should do = FAIL.
not too mention, most oem cars are going wide band. that should tell you something right there.
as said above, your motor is worth more then 200 dollars.
Old Feb 12, 2010 | 10:02 PM
hariku821's Avatar
So this would be better than the uego
Old Feb 13, 2010 | 04:51 AM
Slows2k's Avatar
Inexpensive wideband:
https://www.s2ki.com/forums/index.ph...f=107&t=746030
Old Feb 13, 2010 | 03:43 PM
Moddiction's Avatar
Former Sponsor
I bought a brand new AEM digital wideband on ebay for $179 shipped. Best deal by far I have found. I will see if I can find the seller again as he was a retailer for AEM he said.
Old Feb 23, 2010 | 01:05 PM
bluemetals2k's Avatar
get a wideband
Old Feb 23, 2010 | 02:57 PM
Ahnold's Avatar
Even if you were to use that voltage table, it wouldn't help you. Stock narrowband sensors are only accurate within a small window surrounding 14.7:1 AFR. They weren't designed to do otherwise.
kayvan_pour
Feb 23, 2006 01:18 PM
CRX 18
Oct 17, 2003 09:32 PM
ItalianBucwheat
Sep 23, 2002 11:24 AM
cjb80
Jul 26, 2001 09:08 AM
