Nitrous & clutch
Old Mar 4, 2011 | 06:18 AM
hariku821's Avatar
Jucided ran a 100 shot direct port with out a tune for awhile.The money you will end up spending on a good safe direct port system would probably be better put towards a supercharger though. I am just running a 75 wet shot and even got some things off ebay but I am setting around $1500 in expenses not including the price to fill the tank...
Old Mar 4, 2011 | 11:21 AM
G_whip's Avatar
Originally Posted by Deception
Amateurs dont use nitrous oxide, you'll blow yourself up!
Calm down "Pro" just because i didnt know what the window switch was doesn't make me an amateur.... I ran it on my 99 gsr integra and the hondata ecu had the "window switch" built in. i even programed it myself to run a duel stage dry set up..... with the jrs it made 248 whp and on a 50 shot single stage it made 308 whp.... and considering that I was E.O.D in the Army im sure i can keep from "blowing myself up." Nitrous oxide isn't flammable it is only an oxidizer so if you didn't know the only thing that will blow is your motor...... with that being said the tank can rupture from being exposed to extreme temperature but if no flame is present no explosion can happen
Old Mar 4, 2011 | 11:39 AM
DFWs2k's Avatar
Calm down "Brian Earl Spilner." He was making a reference to a line in "the fast and the furious."
Old Mar 4, 2011 | 11:43 AM
G_whip's Avatar
lol my bad
Old Mar 4, 2011 | 07:43 PM
bluemetals2k's Avatar
use the SEARCH FUNCTION
Hey man theres not to many guys running nitrous on the forums here, well compared to the turbo and sc guys anyways...you can safely run up to a 75 shot stock ecu, I HIGHLY recommend getting a wide band sensor tho its a definite requirement of forced induction. If your looking to do 100 shots and up YOU MUST (for the safety side to it) get a direct port setup ( you should just do that anyways its makes better power ) and some sort of standalone ecu ( aem ems, haltech, flashpro ) and tune, no if's and's or but's about it
heres my info on my build including my 100 shot tune and 125 shot tune
https://www.s2ki.com/.../#entry18731438
https://www.s2ki.com/...h-22-ap2-motor/
some costs you might want to think about are...
Nitrous Setup - around $1500 for a good wet direct port setup ( I have Zex ) including a bottle warmer, 1-2 step colder spark plugs, purge kit, remote bottle opener ( highly suggest it ), and pressure gauge ( you WILL need this high or low shot ) and wide band sensor.
Standalone Ecu - a used one can be had ( Aem Ems for example ) for $800-$1000 some times cheaper
Tune - around $400-$500 ( retunes are cheaper next times )
Aftermarket Clutch - $600-$900 won't need this if your only spraying a 75 shot any higher you will need it, you could prob get away with a few high shots on stock clutch but not for long and it has a better chance of slipping because of all the torque nitrous gives.
Standalone Fuel System - $500... separate fuel cell, fuel lines for the nitrous, return style fpr, and fuel pump. If your going over a 75 shot.
Start with is a good nitrous direct port setup and all the extra's and 75 shot, anything higher buy everything else
Old Mar 5, 2011 | 06:22 AM
JuicedS2K's Avatar
lol, however, its "blow yourself to pieces!"
Old Mar 5, 2011 | 10:58 AM
s2k dre's Avatar
100 shot ftw!
Old Mar 5, 2011 | 11:57 AM
G_whip's Avatar
@bluemetals2k the link doesn't work and thanks for the advice are you doing this on stock internals?
Old Mar 5, 2011 | 12:00 PM
s2k dre's Avatar
Yes bluemetal has stock internals. This block is more than strong enough for nitrous, it could handle a 200 shot with the right fuel set up and tuning. My motor has 140k on it and i been using nitrous for 2 years already.
Old Mar 5, 2011 | 01:38 PM
sites still messed up, search 100 shot and 125 shot or just my name my threads will come up
