View Poll Results: Is nitrous a form of forced induction?
Yes
49.23%
No
50.77%
Voters: 65. You may not vote on this poll
Old Apr 24, 2007 | 08:02 AM
2QYK4U's Avatar
Default Is nitrous a form of forced induction?
I am in a debate with other car enthusiasts as to whether nitrous is truly a form of forced induction. What is your opinion?
Old Apr 24, 2007 | 08:05 AM
Venomous S's Avatar
My opinion is that it is most defenitely a form of FI
You are not necessarily forcing air in the common sense, but you are forcing more particles of oxygen into the mix.
Old Apr 24, 2007 | 09:24 AM
slimjim8201's Avatar
I'm going to lean towards no, it's not a form of forced induction, but it all depends on your definition of FI.
Technically, a naturally aspirated engine is one that "breathes" on it's own. That is, all of it's incoming charge is pulled into the cylinder via the negative pressure developed during the intake stroke. (And perhaps a bit due to resonance supercharging or exhaust scavenging, but thats another topic).
When I think forced induction, I see the term "forced" relating to "additional mass flow" or plain and simple "more air than the engine would normally be able to pull in on it's own".
Nitrous oxide is simply a chemical injected into the induction system. The overall mass of air/fuel/NO2 mixture going into the engine remains about the same whether the N02 is being injected or not. Sure, the thermal breakdown of the N02 results in a higher oxygen charge density, but nothing is "forcing" additonal air into the engine.
It's all a technicality anyways, but I'll keep turbos and superchargers in the F.I. category and N02 in the N02 category.
Old Apr 24, 2007 | 09:28 AM
Dsgs2k3's Avatar
i think no because its not creating boost
Old Apr 24, 2007 | 09:54 AM
Spec_Ops2087's Avatar
According to NHRA it is and I also feel it is as well.
The whole reason why nitrous makes more power over gasoline is because it has oxygen bonded to the nitrogen and with more O2 you can shove more fuel in to make more power. Sounds exactly like a turbo/SC minus the compressor.
Old Apr 24, 2007 | 12:57 PM
spoolins2k's Avatar
It makes more power, but I agree that no it's not in definition.
Old Apr 24, 2007 | 01:01 PM
Planets's Avatar
I guess it's the whole "forced" part that I have a problem with. You're not "forcing" nitrous into the engine and thus creating boost.
Old Apr 24, 2007 | 02:06 PM
Venomous S's Avatar
This is true, you are spraying nitrous into the intake.
I look at it in the sense that if it's not drawn in by negative pressure, then it's been forced either via air itself or by inducing more particles of oxygen.
Now, a car with nitrous, is it naturally aspirated or not?
Old Apr 24, 2007 | 02:56 PM
afwfjustin's Avatar
I vote yes.
Old Apr 24, 2007 | 02:59 PM
Slows2k's Avatar
All N20 topics will be moved to the FI forum. It's FI on s2ki...
