Nitrous trouble
Old May 8, 2010 | 07:11 AM
JoeyBalls's Avatar
I did'nt even know AFR gauges could read that rich...........
Old May 8, 2010 | 07:22 AM
D1sclaimer's Avatar
Originally Posted by s2k dre,May 8 2010, 07:16 AM
IM running a .042 nitrous and .022 fuel jet with a dyno tune nitrous kit and im at 11.3 steady afr and it pulls really hard with 950psi. Make sure ur psi is right and get a smaller fuel jet if needed.
Your sig says you run 110 octane daily for your 75whp shot.
Do you really?
Old May 8, 2010 | 07:27 AM
s2k dre's Avatar
Do you really?
Yea the 110 is right next to my house so i was using it for a while but now im running pump gas with it, u can tell it runs a little better on race gas but my plugs have a perfect timing mark with pump gas. And the afr is the same on both fuels.
Old May 8, 2010 | 08:04 AM
JuicedS2K's Avatar
Why on earth are you only running a 75 shot if your driving with 110 daily? 110 is serious overkill...
Old May 8, 2010 | 08:23 AM
s2k dre's Avatar
cause i wasnt driving much so i used it for a while, i know pump gas is good enough.
Old May 8, 2010 | 08:39 AM
JuicedS2K's Avatar
lol spray that 100 shot
Old May 8, 2010 | 08:47 AM
s2k dre's Avatar
i would but im still on stock clutch. And once i spray 100 shot i wont go back to a 75
Old May 8, 2010 | 09:04 AM
JuicedS2K's Avatar
yea i was spraying the 100 for a while and it eventually roasted my stock clutch.
Old May 8, 2010 | 11:20 AM
s2k dre's Avatar
yup. i have 127k on the stock one.
Old May 15, 2010 | 12:31 PM
hariku821's Avatar
I have a little more info.. Now it seems that neither the fuel or nitrous is working lol.. Im not going rich with it turned on but the bottle off and im not going lean with the bottle on..
But by accident when installing the kit i found out if i remove this one ground wire the nitrous sprays uncontrollably into the intake if its turned on with the ground removed. So i removed the ground flipped the switch quickly on and off and heard it spraying into the intake.
I have also reprogrammed the nmu just to make sure the tps was all working alright still no luck..
