Nitrous.. Wot swtich, Msd WIndow Switch,or Button?
Old May 8, 2005 | 06:18 PM
RCR S2's Avatar
Use all 3.
WOT to ensure proper conditions.
Button switch so you can CONTROL nitrous -- you don't aways want it on and you shouldn't have to lift the throttle to shut it down. Helps with your launch too since you may not want to launch with nitrous -- you'll just smoke up the tires or break an axle.
So in otherwords, WOT and switch pressed to activate the laughing gas.
RPM or pressure switch at the high limit so you don't go overboard. This is your safety net.
Old May 8, 2005 | 06:31 PM
JRock's Avatar
omg totally do this!
Old May 8, 2005 | 07:24 PM
Slows2k's Avatar
I'm merged your 2 threads on this. Please only start 1 thread on the topic. There isn't any need for 2.
Old May 10, 2005 | 02:48 PM
GotRPMs's Avatar
That is the funnyest thing i have seen in a while nice
Old May 10, 2005 | 03:49 PM
AllStock27's Avatar
ummm, i think you guys are making this too complicated....
the zex kit is fairly simple... the dry kit that is.. (no experience w/ the wet kit)
use to have the zex kit before... It WOULD ONLY kick in if 2 things happen: u step on the gas all the way(zex does this by tapping the tps hence) and you have the arming switched on. If you add the msd switch, i would assume u can set it up to go off after a certain rpm... plus the 2 variables mentioned earlier.
as far as being able to control the launch, its not that big a deal... just turn off your switch when u launch, then when you're ready, turn it on.
Old May 11, 2005 | 02:10 AM
Reds2kracer's Avatar
Old May 11, 2005 | 02:11 AM
Originally Posted by Reds2kracer,May 11 2005, 02:10 AM
sorry about that...
liquid_helix136
21
Jul 27, 2015 03:19 PM
Built4Boost
May 26, 2012 09:30 AM
05 S2K Stoner
Mar 10, 2008 05:51 AM
