No Spark with Aem
Today we changed the positive battery cable to a thicker gauge cable. Then I checked the voltage which the aem was reading at around 15 and 12+ when cranking the car.
The Stat sync is still not coming on when cranking the car. Checked everything above a couple of times but no luck.
I think I will be sending in the Aem for service to see if the ignition driver is bad.
First you have to ascertain if you have a spark or not.
Remove a plugpack and spark plug. Put the spark plug in the plug pack (use electrical tape to hold it there) and crank the engine with the threads of the plug against some bare metal of the car. If you see a spark, good so far.
Firing order is 1342.
^^Yeah that's exactly what I did when I checked for spark. Like I said earlier it sparks with the stock ecu but not with the aem.
I am going to send the unit to Aem to get it checked and fixed.
Thanks for all help guys.
You won't get spark until the "Stat sync" comes on.
I had this problem before and battery voltage looked decent too. However I connected another battery in parallel and the system worked.
....may be give it a try
i bet it is in the setup/tune, unless he had some other electrical issues we dont know of.
I just remebered had a car did same thing, ended up being, update AEM software on laptop, then have to update firmware on ecu, reload tune, becareful the basetune is not for the 1012, hit the key and it fired right over.
Originally Posted by Tech7427,May 20 2009, 05:14 AM
I'm doubting this is a ems problem but more like u didn't sync the igniton timing and tps voltage until u do that stat sync won't say ON until u sync timing
