noob question>>>
Old Dec 5, 2006 | 06:26 PM
elusiv's Avatar
Originally Posted by versionJDM,Dec 5 2006, 06:16 PM
my plans are to just bolt up said kit to my custom 70mm header back and go, but my gut thinks that this will cause a LOSS of boost.
Your exhaust wont lose you boost.
Old Dec 5, 2006 | 06:34 PM
Dsgs2k3's Avatar
the exhaust will lean it out some. as for the VAFC to tune it, it does not like to add fuel, only subtract so if you had a FPR you would turn it up and lean out with the VAFC
Old Dec 5, 2006 | 06:38 PM
Johnny Sack's Avatar
i know VAFC and boost are like Ike and Tina, so i plan on selling it, but i just wanted to make sure i didnt HAVE to have it after i bolted the kit on. thanks for the help guys!
7psi+ takes emange/ems and bigger injectors correct?
Old Dec 5, 2006 | 06:42 PM
elusiv's Avatar
Nope... all you need is to replace the pulley and belt if you're running a CTSC. For a Vortech you should already be at 7psi.
Old Dec 5, 2006 | 07:38 PM
Dsgs2k3's Avatar
though keep the vafc for now because at that boost it would be a nice tuning tool
Old Dec 5, 2006 | 08:05 PM
cool. i know on my NA setup 5600 was optimal for vtec, what about you FI guys, where is your vtec at?
Old Dec 5, 2006 | 09:11 PM
scarab45's Avatar
not in my case. I have a ctsc w/o ac running a 7lb pulley and header back exhuast. I tried putting it on the dyno with adding fuel through the fpr and then leaning it out with vafc. Didn't work. I wasn't getting enough fuel so i had to get injectors and emanage.
Old Dec 5, 2006 | 10:45 PM
elusiv's Avatar
[QUOTE=scarab45,Dec 5 2006, 11:11 PM]
not in my case.
Old Dec 5, 2006 | 11:04 PM
afwfjustin's Avatar
You can add some fuel with the VAFC
Old Dec 6, 2006 | 12:04 AM
s0rted's Avatar
Originally Posted by elusiv,Dec 6 2006, 08:45 AM
Maybe I should have clarified a bit more before stating that, but it really did work. 7psi on a car with nothing more than a stock CTSC will work just fine nearly everytime. Tossing an aftermarket exhaust on even a stock 5psi CTSC can possibly lean it out past the FPR's ability to compensate. Chances are your problem wasnt the amount of boost you were running, but was your exhaust.
I can vouch for that. Sticking on a test pipe leaned out my afrs by about 1 point give or take, across the range. Widebands are your friend I was able to compensate with the fpr, but it really wasn't the best setup, so switched over to emanage and larger injectors.
