Novi 1000 leaking boost
Old Jun 1, 2009 | 12:09 PM
jdmdohcpower's Avatar
Default Novi 1000 leaking boost
I have traced a boost leak to the housing of my novi 1000. Leaking right at the back where it meets the blower where the 8 bolts hold it down. Paxton says there is no gasket there and you have some sort of issue. I just had it rebuilt less then 3k ago. Any thoughts how I might fix this, I would love not to have the car down for another 2 weeks while its at Paxton
Old Jun 1, 2009 | 12:47 PM
CosmosMpower's Avatar
How much was the s/c rebuild, did you do a full rebuild or just seals?
Old Jun 1, 2009 | 12:52 PM
ThatPreludeGuy's Avatar
There was no warranty on thier work?
Old Jun 1, 2009 | 01:09 PM
Well they did a full rebuild but while putting on my FMIC I had to rock the housing and stripped one of those bolts. I tapped it to a larger size so I doubt there will be a warranty. Also there is no seal on the housing. Its metal to metal.
I was thinking a strong gasket maker???
Old Jun 1, 2009 | 02:00 PM
s2k aok's Avatar
Thumbs up
yeah, how much was the rebuild? source?
was it a complete rebuild?
with mine the bearings are quiet as hell, can i just have the seals replaced? i cannot locate an illustrated parts breakdown of the supercharger/internals, don't suppose anybody has this?
Old Jun 1, 2009 | 03:49 PM
Did you rebuild yours already? My bearings are loud and the more I listen to it the more I think they're on tehir way out and gettng loud. What bearings silenced the blower for you?
Old Jun 1, 2009 | 04:15 PM
I had paxton do it. $400
Old Jun 1, 2009 | 05:21 PM
scarab45's Avatar
so you think this is the reason you were seeing such boost lose with the ur fmic?
Old Jun 1, 2009 | 05:32 PM
I hope so, there was a leak for sure so we will see. Looks like its going back to Paxton tomorrow so it will be some time before I know.
Old Jun 2, 2009 | 07:44 PM
bluemetals2k's Avatar
with a fmic your will lose anywhere between 1 and 3 psi of boost just to let ya know getting my info from many other situations i've read with sc's and fmic's here on s2ki
