Getting really low numbers on tuned greddy kit
Old 02-28-2018, 06:58 PM
ryiin2's Avatar
Default Getting really low numbers on tuned greddy kit
I have a semi customized greddy turbo on my 03 AP1, and had it tuned only to make very low disappointing numbers.
Greddy Kit
AEM v2
3in DP/ Single Exhaust
Pfab externally gated replacement manifold
sos 3bar map sensor
38mm tial ewg
550cc RC injectors (came w/greddy kit)
Tuned at 10psi on dynapack (which reads 8-10% higher, or so i've read) I made a pitiful 254 hp and 203 ft/lbs torque. Graphs attached.
Is this normal? I thought numbers closer to 300 were more common.
Old 03-01-2018, 06:09 AM
AP1Chief's Avatar
PM'd
ryiin2 (03-01-2018)
Old 03-01-2018, 11:47 AM
nguyen365's Avatar
Greddy Kit
AEM v2
sos 3bar map sensor
38mm tial ewg
Something off there
ryiin2 (03-01-2018)
Old 03-01-2018, 01:03 PM
MARK AUS S2K's Avatar
I have also read that Dyno-Pack will read lower! This has also been backed up time and time again.
ryiin2 (03-01-2018)
Old 03-01-2018, 01:12 PM
Mijae007's Avatar
actually i think its the other way around, dyna-packs read high and dyno-jets read lower.
ryiin2 (03-01-2018)
Old 03-01-2018, 01:32 PM
Yes I have read that too by the internet, however since my car is being dyno'd on a Dyna-Pack I decided to look into it further.
I found lots of large well known business's who have both types do back to back comparisons and their Dyno-Pack read lower by around 8%.
I could not believe this because in theory you have less loss through wheels.
ryiin2 (03-01-2018)
Old 03-01-2018, 03:34 PM
riceball777's Avatar
i would thing something is wrong. The greddy kits are really bad kits in terms of power but your running an aem ems with a full 3 inch exhaust system. You should be making at least over 300whp no matter if its a high or low reading dyno. Some dyno pacs read lower than dyno jets and some read higher than dyno jets. Depends on how they setup the dyno and the location of the dyno. I personally dyno at church automotive dyno which uses a dyno pac and they are at sea level and there dyno is known for reading higher than normal.
The following 2 users liked this post by riceball777:
ryiin2 (03-01-2018), StocS2k (03-01-2018)
Old 03-01-2018, 10:48 PM
s2000Junky's Avatar
Are you using a log manifold? If so, consensus is needing a higher then stock vtec (around 7k rpm) engagement point to not have the power drop off prematurely. Could be your main issue.
Old 03-02-2018, 12:03 AM
ryiin2's Avatar
Thank you to everyone for their insight, help and comments!
I think something is definitely wrong somewhere, but I don't know what it could be. After spending a lot of time lurking the forums specially the greddy kit numbers people tend to get in the 280-290, with my setup I did think i was going to go over 300 but boy was I wrong.
Old 03-02-2018, 12:04 AM
ryiin2's Avatar
Yes I am using the PFab log manifold (greddy kit replacement because the greddy one had cracked), and my vtec is pushed to 7k already.
Quick Reply: Getting really low numbers on tuned greddy kit
