Novi 1200 - Max Power?
Novi1200 with 3.4pulley and ASP crank pulley will put you around 19.8 psi with a blower speed of 56592rpm. Understand, max blower speed is 52000rpm
Also I doubt my little Bosch BOV will deal with that pressure, will a 25mm turbosmart valve be ok? I do have an HKS flange but really don't want to go down that route after what I've read on here?
The formula for calculating blower speed is (crank pulley size / blower pulley size) * 3.61 * engine RPM = Blower RPM The 3.61 is the blower step-up ratio. For example on your setup. (6.5 / 3.4) * 3.61 * 8000 = 55,212rpm
I was running two Bosch valves on my 1220 setup with a 3.4" pulley and was getting surge at high rpm throttle lifts. The 1200 flows more CFM and for what you are doing you will need to upgrade. I personally went with a Tial QRJ with the -1.5psi spring. I tested it on my 1220 before I sent it off and it evacuated a TON more air. I may need to still add a Bosch to the air pomp nipple, but I am hoping that I wont.
Thanks - can you give me some idea of the belt size once you get yours? SOS have said they are waiting for more 1200's which will be 2 weeks. I also ordered it with th 3.4" so I'll have to deal with it.
I've ordered the Bosch 710P as a replacement valve which are rated to 2BAR. What is boost surge? Where the air can't evacuate quick enough? I might order a second 710P and add it to the air pump inlet. I believe the 710P was standard on the RS6 and other high flow applications??
Guys - another thread has prompted me to double check my setup.. I'm just wondering if I have everything I need to support 16-18PSI with this setup.. I realise 500whp won't de doable with the fuel I'll be using but will my fuelling and other mods be sufficient? My spec:
AP1 1999
N1200 (6.5" crank / 3.6" pulley)
Fuel - 98RON (New Zealand) I think this is equivalent to your 93 pump but I'm not sure.
ID1000
Walbro 255 in tank pump + OEM FRR
High compression JDM spec motor - stock (230~235psi comp test)
New coils and plugs (as recommended on here)
Currently running ~14PSI on my N1000 and have been for a year with 420whp.
Are the above mods capable of supporting that boost? Not so much in terms of reliability but in terms of detonation etc.. Will the tuner be able to pull the timing so he can still produce a safe tune or do I need less boost? Will fuelling be ok? (will I need an FPR?) I'd prefer not to change the pump again if I don't have to.
Please let me know - thanks all.
AP1 1999
ID1000
AP1 1999
ID1000
AP1 1999
ID1000
Hi, you should be seeing 16-18 depending on your setup.
Go here:
http://www.calculatoredge.com/mech/vbelt%20length.htm
use 13.26 as the centre distance to calculate your belt length.
Go here:
AP1 1999
ID1000
AP1 1999
ID1000
