odd ems not reading AF
Old Dec 25, 2008 | 06:03 PM
GDM S2K's Avatar
Default odd ems not reading AF
this may sound wierd but my lap top is reading a totally diff number than my gauge is reading. ive connected all the wires to the correct spots. when I remove the ground the number drops. anyone have any ideas?
Old Dec 25, 2008 | 06:08 PM
ChefJ's Avatar
Is the EMS calibrated for the wideband you have hooked up?? I had to calibrate mine. I have an autometer wideband and it wasn't an option so I had to play around with the calibration until they matched up. Its a certain voltage output/input.
Old Dec 25, 2008 | 06:23 PM
candymanjl's Avatar
make sure you calibrated the sensor according to the directions, with the AEM sensor you just have to set the voltage gain until it matches the number they tell you to aim for. if this is correct then try this...
also the AEM software is a little retarded. in every single case I've installed the software, even though the software shows the right units selected under the units menu, they displayed wrong. for the load units and AF ratio units I've always had to the menu, select something else, then select what you want to see (most likely PSI and Gasoline AFR) and then it'll display correctly. I've only had to do this after the initial software install or after an update to the software. once that's set it's been fine.
Old Dec 26, 2008 | 07:36 AM
GDM S2K's Avatar
thanx ill try it tongih
gotta love aems bugs
superfly77
Sep 11, 2016 04:46 PM
Reapur
Apr 7, 2012 05:10 AM
dsddcd
Forced Induction For Sale
Mar 9, 2011 03:00 PM
skool u
Jun 23, 2010 10:46 PM
Spec_Ops2087
Oct 26, 2007 08:41 PM
