OIL COOLER BLOCK OFF
Old Mar 12, 2014 | 08:25 PM
Juniorbr19's Avatar
Default OIL COOLER BLOCK OFF
I am installing a mase kit that i purchased from someone in this site.... i thought it was a built on kit, but now I'm realizing its not... the exhaust manifold touches the hose thats just above the oil filter. I was wondering if that hose (which i know is a cooling system for the oil) is necessary... has anyone blocked it off before? Please let me know whats your experience if you have been through similar issues... thanks in advance
Old Mar 13, 2014 | 04:06 AM
camuman's Avatar
Not needed depending in your driving style. If you do a relocate kit you add capacity to the system and it's Def fine for street fun. That's what I have.
Old Mar 13, 2014 | 04:54 AM
weiRtech's Avatar
I replaced mine with an oil cooler by adding a spin on sandwitch adapter.
here is the adapter (made by earl's)
here you can see the new lines going to the oil cooler which is in the top right corner of the pic:
I will be redoing it all though when I add a dry sump system this spring.
aaron
Old Mar 13, 2014 | 05:42 AM
rikhemi's Avatar
Just a heads up. Keep an eye on that manifold. Tends to crack.
Old Mar 13, 2014 | 06:40 AM
passmans2kny's Avatar
Originally Posted by weiRtech
I replaced mine with an oil cooler by adding a spin on sandwitch adapter. here is the adapter (made by earl's) here you can see the new lines going to the oil cooler which is in the top right corner of the pic: I will be redoing it all though when I add a dry sump system this spring. aaron
sick lines!
Old Mar 13, 2014 | 06:57 AM
camuman's Avatar
thank you for your concern. what leads to this thought?
i'm confident it won't. I built it.
aaron
you built the mase manifold? or used mase kit but different manifold that you built?
Old Mar 13, 2014 | 07:04 AM
weiRtech's Avatar
my bad. I thought the response was aimed at the one pictured, not the mase kit. me duh.
Old Mar 13, 2014 | 07:42 AM
redboost10's Avatar
weitech, thats the nicest looking topmount s2k manifold i have seen.
Old Mar 13, 2014 | 08:00 AM
weiRtech's Avatar
thank you. too bad it won't fit in an s2000. lol!
here is another shot:
aaron
s20004lifehomes
Nov 19, 2009 04:53 PM
kutsujula
Dec 12, 2007 11:03 AM
Soul Coughing
May 16, 2007 09:22 PM
Gruppe-S
Jun 20, 2006 03:24 PM
Venomous S
Aug 13, 2005 04:40 AM
