oil feed pressure question
hi guys i am planning to install a gt28 on the S so for the oil feed line does anyone know the pressure? i could get it from the oil pressure switch or i could also tap into my oil filter relocator sandwich but i have no way of testing pressure on either place, according to garrett the GT28RS wants to see 3-4 bar (45 to psi) of oil pressure to be happy and well fed during operation. The pressure can be less at around 15-20 psi at idle i am planning to use a -3an line with a 0.35 restrictor ( since that wat everyone on here recommend )and a -10 return line Thank you so much for any help!!
Yup, that's why. You don't want to feed the spool with straight -3 or -4AN hose. That turbo will not last long, it will seep oil past its seals, and that oil will be carbonizing, creating a relatively abrasive powder, which in turn, under high rotational speed will rub against the seal. Cause and effect, you get the picture.
So under that 90psi pressure (~6 Bar), the in-line oil restrictor will not limit the pressure as much as the volume of oil getting to the bearings in the CHRA.
I bought my off of E-bay, some VW turbo accessories vendor or something.
-3AN or -4AN that makes zero difference. I my memory still serves me you will want a .035" on a BB and .065" for a Journal
I fyou pull off the OP pressure switch port you will be seeing clean oil right out of the filter through an internal passage in the block. Just install a Tee fitting and pull you feed off this.
Good luck and post up some dyno's I have always that the GT28 would be a great option for the S2000! It should be a great compromise for power and spool.
S2K-F8
May 25, 2017 10:56 AM
s2k manic
Dec 13, 2012 01:47 PM
