oil and filter
Old May 11, 2009 | 05:55 PM
GpWaP1 s2k's Avatar
Default oil and filter
i am getting ready to install my inline pro turbo kit...i was just wondering what some of you guys are running as far as oil and filters go? like what brand of oil? weight? brand of filter? i was told to use synthetic 10W-40 for a turbo S...
Old May 11, 2009 | 06:14 PM
dsddcd's Avatar
Look for a non-energy conserving oil which is often advertised as Euro formula, personally I like MOBILE 0W-40 but Castrol and others make it. I also like Mobile's oil filters they are made by the same people that make K&N's and some others but at a lower price and they are readily available. If you have a Honda dealer near you the S2000 specific filter is very good.
http://www.mobiloil.com/USA-English/MotorO...il_1_0W-40.aspx
Hope you like your new kit, which kit did you get anyway?
Old May 11, 2009 | 06:23 PM
SgtB's Avatar
OEM filter and 40wt. 50wt if the turbo's super hot. You need to pick a weight that's not going to turn into water at high temps and break down.
Old May 12, 2009 | 03:20 AM
GpWaP1 s2k's Avatar
i got the regular inline pro kit...so you are saying that you use a 0w-40 or 0w-50? and not 10w-40 or 10w-50?
Old May 12, 2009 | 05:34 AM
dsddcd's Avatar
Are you N/A now?
Read some of this thread, it will help explain
https://www.s2ki.com/forums/index.php?showt...&#entry15015689
Old May 12, 2009 | 05:47 AM
siadam's Avatar
OEM filter + Mobil 1's 10w 30 here.
Old May 12, 2009 | 03:54 PM
Irishflame27's Avatar
10w-30 castrol syntec and oem filter is what i will be using
Old May 12, 2009 | 04:16 PM
JoeyBalls's Avatar
just made the switch from MOBIL 1 to AMSOIL 10w-30, as far as Filters go I have been using NAPA Gold ones, so far it hasnt any caused any failures
AMSOIL FTW
Old May 12, 2009 | 07:58 PM
SgtB's Avatar
30wt Joey? You should be running thicker.
Old May 12, 2009 | 09:29 PM
passmans2kny's Avatar
mobil 1 10w-30 here oem filter is what I'm running
