oil and filter
Old May 12, 2009 | 09:36 PM
Kyushin's Avatar
Banned
Originally Posted by JoeyBalls,May 12 2009, 07:16 PM
just made the switch from MOBIL 1 to AMSOIL 10w-30, as far as Filters go I have been using NAPA Gold ones, so far it hasnt any caused any failures
AMSOIL FTW
I totally agree, but jesus christ amsoil is getting harder and harder to find in stores ><
Old May 12, 2009 | 11:09 PM
bradshit's Avatar
AGIP 10w60 racing
perfeckt for thoses that are running hard and running on track
Old May 13, 2009 | 04:34 AM
JoeyBalls's Avatar
Originally Posted by SgtB,May 12 2009, 07:58 PM
30wt Joey? You should be running thicker.
hmmm I was under the impression that all oil is essentially the same "weight" when warmed up its only during the start where there difference is seen?
I will switch to a thicker oil if it helps I just figured I would go with OEM specs, as far as finding AMSOIL, I order from there online store its like $7.xx a quart but was delivered next day
Old May 13, 2009 | 04:48 AM
s_d2k's Avatar
Originally Posted by bradshit,May 12 2009, 11:09 PM
AGIP 10w60 racing
u like the AGIP oil?
Old May 13, 2009 | 07:36 AM
SgtB's Avatar
Nope. The two numbers indicate all the cold/ hot characteristics. Think of it as coldW-Hot. Your definitely not OEM either. Think of how hot your oil gets running through the turbo's center cartridge when it's glowing red hot. The hotter an oil gets, the thinner it gets. If the oils not made for that temp range it thins out and looses it's lubricating properties. The spec you need to match is high temperature shear.
It may not be as much of an issue on a water cool turbo, but we're oil cooled.
Old May 13, 2009 | 07:53 AM
JoeyBalls's Avatar
got ya thanks, yeah I hear my TCT ticking after car gets hot, I contribute that to the SUPER thin Mobil 1.
I will use this batch of 10w-30 AMSOIL then switch to 10w-40 after 3,000 miles thanks
Old May 14, 2009 | 04:21 AM
asukadc's Avatar
motul 300v 10w40, + ams oil filter.
bubsie007
Oct 21, 2013 11:25 AM
GrandMasterKhan
Jun 13, 2013 04:26 PM
Grillo
Apr 23, 2012 04:20 PM
Ualreadykno
Apr 25, 2008 09:05 PM
S2K-F8
Oct 29, 2000 08:37 AM
