Oil filter relocation kit, With stock oil cooler!
The stock oil cooler/warmer really helps with getting the oil to operating temperature, especially in the winter. Last winter, i didn't run coolant lines to my stock oil cooler and the oil wouldn't go over 110 in 30 degree weather. I have since installed a MOCAL oil cooler, and my oil temps in 30-40 degree weather is at least 50 degrees warmer than before. I would much rather have the stock oil cooler than none, that's for sure!
It's a mod that I came up with to get my engine to last as long as possible with minimum maintenance. It's working great.
Originally Posted by Leviisbigred' timestamp='1321944370' post='21176592
do tell.. bypass filter & prelube pump setup.. i dont know everything
is it a mod? a fix? better?
is it a mod? a fix? better?It's a mod that I came up with to get my engine to last as long as possible with minimum maintenance. It's working great.
