Oil filters
Old Mar 13, 2009 | 01:57 PM
phils2k's Avatar
Default Oil filters
I am in the process of changing my oil, and i have a new small Hamp oil filter, just wondered if any other people are using them or advise not to, or are you using OEM
many thanks phil
Old Mar 13, 2009 | 02:36 PM
AndyFloyd's Avatar
Ive used OEM and Mobil 1, personally i dont think there was much a difference between the two. OEM is what i use now though. Figure honda most likely got it right.
Old Mar 13, 2009 | 02:49 PM
Soul Coughing's Avatar
Going from the road rage articles, i have and will only use OEM.
Old Mar 13, 2009 | 03:00 PM
tony1's Avatar
I picked up 10psi oil pressure at high rpm with a K&N oil filter over stock and fram...
Old Mar 13, 2009 | 03:03 PM
phils2k's Avatar
do explaine sorry to be thick
i understand the hemp filters hold higher pressure, i may just go and buy a stock one as i dont wanna shaft my set up
Old Mar 13, 2009 | 05:00 PM
are you sure the bypass valve isn't opening up at higher rpms?
Old Mar 13, 2009 | 05:13 PM
RichV's Avatar
OEM PCX filter Redline 10w-40 oil
Old Mar 13, 2009 | 08:21 PM
siadam's Avatar
I've used oem in the past. I bought 2 for my new setup.
I think I pay like 5-7 bucks per filter.
Whats the costs on the k&n ?
Old Mar 13, 2009 | 08:26 PM
EternalLx's Avatar
well.. fyi.. some turbo guys cant use OEM honda filters.
I would like to know if K&N is good too since am switching to the canton racing filter adapter. I would have to use oil filters that fit with most Fords.
Old Mar 14, 2009 | 05:20 AM
macprotege5's Avatar
i use a wix filter for mine, its part # 51334 never had any problems with it, and it even says official nascar filter, ha ha.
