oil jet upgrade
Old Aug 15, 2007 | 11:39 PM
lend_type_R's Avatar
[QUOTE=ChefJ,Aug 15 2007, 11:20 PM]^ not good when you are at the dyno doing 9000 rpm pulls.
Old Aug 16, 2007 | 02:51 AM
Reborn56's Avatar
Yes Soul coughing is proof of this.
Its not too bad to install anyway
You should DEF put these in
Old Aug 16, 2007 | 04:06 AM
PWRMKR's Avatar
I ran without upgrading for a few k after I installed my SC. It is cheap insurance if you are going to drive the car hard on long stretches.
If your car is staying local, you should not have any problems.
All the F engines (and most all modern engines) have under piston squirters. The later AH years and all the Euros squirt more oil. The Euros due to the extended high speed freedom that we do not have and the later AH are from lessons learned.
Old Aug 16, 2007 | 04:15 AM
GDM S2K's Avatar
Originally Posted by lend_type_R,Aug 16 2007, 02:30 AM
no bonjo bolts? how did you direct the oil under the piston and cylinder?
im sleeved so there is no need for them.
Old Aug 16, 2007 | 07:40 AM
Danks2k's Avatar
I've had my supercharger for around 5k miles so far and no problems. Granted I had not read that this is a really good idea to do for a superchargered car otherwise I would have done it while I had the pan off to tap it Doh!. I think I might upgrade to them in a couple months then for peace of mind.
Old Aug 17, 2007 | 06:20 AM
ShMooveS2k's Avatar
where can i purchase these oil banjo bolts?
Old Aug 17, 2007 | 06:23 AM
S2KPANG's Avatar
At the Honda dealership.
Old Aug 17, 2007 | 07:27 PM
s2guru's Avatar
HERE
Old Aug 18, 2007 | 08:05 AM
ShMooveS2k's Avatar
thanks!
erikvanden
May 14, 2011 06:14 PM
nMeOnE
Oct 7, 2007 06:40 PM
shepherddog
Apr 27, 2007 04:35 AM
KLN
Mar 8, 2005 10:24 AM
TepEvan
Feb 18, 2004 12:48 PM
