oil pan
Old Apr 10, 2008 | 08:23 PM
outlawzs2k's Avatar
Default oil pan
hi
does anyone know.. i try to taking off my oil pan but its got stuck? its wont come out?? anyone why?? cause right now im try to put sc in..
Old Apr 10, 2008 | 09:08 PM
kix's Avatar
kix
Make sure you removed all the bolts... It also has sealant around it which is like glue.
Old Apr 11, 2008 | 09:42 AM
03silver2000's Avatar
you might kind of have to pry it down
make sure all of the bolts are off first=)
Old Apr 11, 2008 | 10:02 AM
Danks2k's Avatar
Lots of bolts make sure they are all off and then on one side there is a tab that you can use to pry it from the block. It will be stuck on there pretty good.
Old Apr 11, 2008 | 07:30 PM
Kwando's Avatar
if all the bolts are off its prob just the sealant that is holding it on. Double check the bolts and then try to pry it open. I have one that is off that i can take a pic if you need it.
Old Apr 11, 2008 | 07:58 PM
outlawzs2k's Avatar
thanks guys... Kwando if you can taking pictures for me.. thats would be help..
thanks
Old Apr 11, 2008 | 09:23 PM
Kwando's Avatar
AndyFloyd
Aug 14, 2012 11:52 AM
shift9k
Mar 7, 2012 01:22 PM
JDM S2000
Oct 3, 2006 06:09 AM
VTECturbo04
Dec 16, 2004 03:04 AM
Scott M
Sep 18, 2003 10:26 AM
