oil pressure fluctuate at steady speed
question to people with oil pressure gauges,
while idle after a drive, how much does ur oild pressure fluctuate?
and while driving at a steady speed? is it normal for oil pressure fluctuate about 30 psi while driving at a steady speed ?
And is the fluctuating sporadic or follow a specific trend? Is it better or worse at certain RPMs? Could be a sensor going bad.
im just looking at it while driving.
Originally Posted by boostedf22c' timestamp='1416923700' post='23417518
[quote name='henrryxd' timestamp='1416890243' post='23417226']
[/quote]
Where is there a good place on the intake manifold side to read oil pressure? Has it done it the entire time you've had the gauge?
I
originally i had the sensor on the turbo manifold side was readying 5 psi apart at steady driving. then it started to read 0,
guessing it was because it was too hot and relocated it to the intake manifold side, worked fine,
then started to fluctuating alot, decided to replace the sensor,
got a little better but its still fluctuating but not as crazy as before.
thing is its different from how the reading was originally.
not sure if im making sense. =[
S2K-F8
Apr 29, 2017 06:47 PM
cheddaboy
Dec 6, 2015 02:41 AM
josserman
Aug 18, 2010 06:55 AM
Moddiction
Jul 8, 2010 02:24 PM
