Oil return line leak
My Oil return line is starting to weep a little oil, after 2 track days in a week it's getting worse. Must be the hard use on the race track.
Anyone else have any leakage?
For the last year since I installed the SC there was a little oil residue, now there is enough to make a small spot on the garage floor.
It's hard to tell where it's leaking from, the AN fitting or from the drain plug fitting.
When I bought the kit used, there was not a return line so I made my own using Aeroquip fittings and hose. I was very careful assembling the hose.
I wonder if should replace the hose with the over priced pre-assembled one from Comptech.
I would recommend replacing your fabricated line with the original Comptech line. It may cost more but you'll have peace of mind.
That line is under load/pressure so I would recommend getting the one that was made for the kit before you damage anything else or worse the line disconnect or rupture.
I would disagree. There is no pressure in the return line and Comptech aren't renowned for making good lines (such as the weeping fuel line incident).
I would have just diassembled the line, checked for contamination or faults and reasssembled.
SpeedTheory
Sep 7, 2007 05:18 PM
