Oil return question
Old May 15, 2014 | 07:57 PM
shadowmd's Avatar
Default Oil return question
Quick question. I have the pfab log manifold turbo kit with the 5858 BB turbo. I need to know where I should route my oil return. I'd like to stay away from tapping the actually block ( will if I have too). Anyone route it to the chain case or is that too far away? Any help would be great! Thanks!
Old May 15, 2014 | 11:34 PM
benes2k's Avatar
just tap the oil pan.
Old May 16, 2014 | 05:33 AM
CoolGuy094's Avatar
Don't people put a fitting on the timing chain cover?
Old May 16, 2014 | 06:32 AM
shadowmd's Avatar
I would like to route it that way but wasn't sure with it being a top mount setup, if that would be too long of a drain line
Old May 16, 2014 | 07:06 AM
baZurk's Avatar
I have a top mount and my drain goes to the timing chain cover. It is going to be about the same length as it would be with a sidewinder. Just make sure you have a 60 degree or 90 degree AN fitting to go on the timing chain cover
Old May 16, 2014 | 07:11 AM
camuman's Avatar
Front of pan is also fine.
Old May 18, 2014 | 01:06 PM
9KRPM2.0's Avatar
I am also wondering where the best location for this would be. TC cover seems to be best and easiest. Also reverisble if needed.
spessx
Apr 16, 2024 11:49 AM
liquidgsr
Mar 16, 2016 05:47 AM
aitrus16
Apr 25, 2012 08:34 PM
Deception
May 16, 2011 10:34 AM
