which oil to use?
Old Feb 9, 2006 | 07:25 AM
quickysrt's Avatar
Default which oil to use?
which type of oil do you guyds use? which grade?
Old Feb 9, 2006 | 08:08 AM
passmans2kny's Avatar
10w 30
Old Feb 9, 2006 | 08:14 AM
gomarlins3's Avatar
Manual says 10W30.
Old Feb 9, 2006 | 08:36 AM
Spoolin's Avatar
I use 10w40 because having a turbo and hotter oil, you want the oil to stay a little thicker when hot. Hence the w40 instead of w30. Oil pressure will go up slightly also, which is fine.
Old Feb 9, 2006 | 09:11 AM
ScottyBallistic's Avatar
general rule of thumb is to go up one weight for FI
Old Feb 9, 2006 | 09:17 AM
XclusiveAutosports's Avatar
Is it still reccommended to use 10w40 for a turbo'd car if you live in a cold area like NY in the winter?
Old Feb 9, 2006 | 10:15 AM
gomarlins3's Avatar
I did not know that, thanks.
Old Feb 9, 2006 | 10:35 AM
quickysrt's Avatar
thank you 10w 40 it is
ill get some mobil1 since my other rides use it, the "s" should too.
Old Feb 9, 2006 | 11:41 AM
gusrock77's Avatar
i use Mobile 1 synthetic 10w30 ...but the last time i went to Spugen, Ricardo recommended 0w30 ...im running on that right now and it runs fine ...though i dont know what the difference is...
Old Feb 9, 2006 | 11:49 AM
Spoolin's Avatar
10w30 is the same as 10w40 in the cold start viscosity department. The 10 basically represents how thick the oil is cold and going from 10w30 to 10w40 is the same. The w30 or w40 represents the hot viscosity. I definitely wouldn't recommend going to 15w50 or 20w50 for cold areas, but for warmer all year round areas it would probably be fine.
Now if they made a 10w50, that would be the perfect oil IMO for my climate(40 deg to 80 deg weather) and turbo setup.
