Over boosting problem.
Old Oct 20, 2015 | 06:39 PM
5thgen's Avatar
Originally Posted by Hershey
I try running off wastegate spring by using the compressor nipple pressure to the bottom port of the wastegate and it still over boosted.
Typically this is the lowest boost you can run with your setup. I would swap spring pressures as already suggested.
I would then try to get a good baseline on what a lower rated spring does by itself.
Old Oct 21, 2015 | 08:04 AM
Hershey's Avatar
Here goes the inside. All 4 screw is on good. Diaphragm is good.
Old Oct 21, 2015 | 08:05 AM
Hershey's Avatar
I'm going to put another in and try and see if it holds pressure.
Old Oct 24, 2015 | 08:27 AM
Hershey's Avatar
Today I install a 5 psI spring onto my wastegate and did some test run. 3rd and 4 gear. The car would hold boost @7 lbs up to 6500rpm. After that this thing creeps without not control again. It hit my boost cut at 16psi. My boost wastgate base duty is set at 0. I try upping the number but found out that's just att more boost. Any new idea?
Old Nov 3, 2015 | 06:18 PM
KaNgArOo's Avatar
No ideal about your boost creep issue. But just wanted to point out that we have almost the exact same turbo setup. Haha.
Old Nov 4, 2015 | 03:34 AM
staylor725's Avatar
Sounds like you checked all the parts and they are ok, may just be in the tune.
Old Nov 4, 2015 | 04:01 AM
spectacle's Avatar
It sounds your gate is not big enough to control the turbo up top, or you could have retarded timing at high RPM's that it causing this issue. I would get a tuner to go over the tune for you first before I tried switching out anymore hardware.
Did you verify that the gate opens at 5psi like you did with the last spring?
Old Nov 4, 2015 | 04:54 AM
Hershey's Avatar
Nice. Whats your injector duty cycle at?
Old Nov 4, 2015 | 04:56 AM
Hershey's Avatar
Yeah. I had another forum member took a look at my tune and he fixed some stuff. Car is running better but still over boost.
Old Nov 4, 2015 | 04:59 AM
Hershey's Avatar
Yeah. I wish my local tuner wasn't such a jerk and would look at my tune. So far I been in contact with other tuner but no one has look at the map yet. I did verify the gate does open on the 5 psi spring. Cracks open at 5 to 6 psi and fully open at 9psi.
