overboosting!
Old Dec 21, 2010 | 12:06 PM
purekoryo's Avatar
Default overboosting!
I am currently overboosting even though my 38mm tial wastegate is set at I believe 8 psi spring (the boost cut was at 15.9 psi. I have the MAC solenoid wires connected to the AEM EMS pins D16 and D4. Port 1 off of the MAC solenoid is T'ed to side of wategate and turbo, and Port 2 goes straight to the top of the wastegate. The Boost WG Duty Min is set at 10.2% and Max at 85.2%. Is the MAC solenoid Normally Open? In other words, if there is a bad wire connection would the solenoid stay open? Any ideas?
Old Dec 21, 2010 | 02:16 PM
DFWs2k's Avatar
you can wire it up to be normally open or normally closed AFAIK
Old Dec 21, 2010 | 02:45 PM
purekoryo's Avatar
How do I wire it up to be normally closed? Btw I also disconnected the solenoid wires but still getting the same thing; I'm assuming mac solenoid are normally open then? Does the polarity matter on the two wires off of the solenoid? The cold weather shouldn't increase the boost by 2 psi right? I now have the boost cut set at 10 psi.
Old Dec 21, 2010 | 04:06 PM
Suzuka_Joe's Avatar
Mine is running off the wg 8psi right now because it's so cold and I hit 8psi and hold strong. Somethings wrong
Old Dec 21, 2010 | 04:40 PM
DFWs2k's Avatar
my setup was getting an extra 1.5 psi over what it is setup for
Old Dec 21, 2010 | 05:14 PM
purekoryo's Avatar
Maybe I got a batch of mac solenoid that is normally open?
Old Dec 21, 2010 | 05:18 PM
3en's Avatar
3en
Are you using plastic or metal tees?
Old Dec 21, 2010 | 05:29 PM
purekoryo's Avatar
Plastic. Which should be fine.
Old Dec 21, 2010 | 05:38 PM
DFWs2k's Avatar
I THINK that normally open/closed depends on which wire you wire to what, just Google it, i will when I get near a comp
*edit* that is wrong, looking it up...
Old Dec 21, 2010 | 05:46 PM
purekoryo's Avatar
Well I disconnect both wires and still overboosts. I may also try just bypassing the solenoid and just run a line from turbo straight to the side of the wastegate and leave the top fitting of the wastegate open.
