overboosting!
Old Dec 22, 2010 | 12:19 PM
  #21
camuman's Avatar
so before when you were overboosting, any damage done?
Old Dec 22, 2010 | 12:45 PM
  #22
3en's Avatar
3en
I had the plastic fittings and one side melted causing me to overboost. I have since switched to brass. Just fyi
Old Dec 22, 2010 | 02:50 PM
  #23
purekoryo's Avatar
I did a compression test and came out to 220-230 psi. I didn't see any milky coolant inside the radiator and I checked the dip stick and didn't see any milky oil.
Old Dec 22, 2010 | 02:51 PM
  #24
purekoryo's Avatar
Maybe I should buy a leak down tester as well?
Old Dec 22, 2010 | 07:09 PM
  #25
Suzuka_Joe's Avatar
Originally Posted by Suzuka_Joe,Dec 21 2010, 07:39 PM
The top and bottom ports on the wg should have a vacuum line connected
I guessed right.
Old Dec 26, 2010 | 05:59 PM
  #26
purekoryo's Avatar
Originally Posted by Suzuka_Joe,Dec 21 2010, 05:06 PM
Mine is running off the wg 8psi right now because it's so cold and I hit 8psi and hold strong. Somethings wrong
Why didn't you just add more fuel rather than lowering the boost? What psi were you at before?
vxn12
Dec 2, 2013 03:29 PM
passmans2kny
Jul 22, 2011 12:51 PM
AusS2000
May 5, 2011 06:50 AM
Reborn56
Nov 5, 2006 06:06 PM
NightStalker
Aug 30, 2005 12:08 PM
