Overheating issues
Old Feb 8, 2015 | 04:00 PM
Juniorbr19's Avatar
Default Overheating issues
Hey guys, I've been building my S2K for a few months now. I got almost everything done to it, and now that I'm putting the engine back together I'm running through this problem that's making me loose my mind. I changed sleeves, pistons, rings, rods, and I balanced everything and I added a block guard to the block It looks sick! Following all the correct steps I finally put the engine back together, and when I turn it on, it sounds amazing. Taking it easy to break it in in the first few hundred miles before I can tune it and dyno it. The issue is that it's getting hot. I have read all kinds of advice at this site, but still can't figure out what's going on. The bottom hose feels like there is no hot water coming through it. The heater doesn't work and the temperature keeps going up. Of course I don't let it get to the red, but if I keep it on, it will get there. I put the car up and bled the system many times from both bleeders, and I get coolant coming out of them when they are hot. I checked the hoses and they both seem fine from the beginning to the end. I also changed the thermostat to a new one from Honda. The old one had nothing wrong with it. I also changed the water pump. At this point I'm lost and have no idea what else to do. If anyone went through a similar problem please let me know. Any help will be greatly appreciated
[attachment=73662::]
Old Feb 8, 2015 | 04:23 PM
jaundice's Avatar
If you don't have heat, there is still air in the system. This is a very difficult car to bleed the cooling system. Needs to be burped or will continue to overheat.
Old Feb 8, 2015 | 05:28 PM
99SH's Avatar
Google Lisle 24680
It's a priceless tool when it comes to bleeding the cooling system.
Old Feb 8, 2015 | 06:07 PM
Spoolin's Avatar
You must bleed the system on these cars with the front end raised up.
CoolGuy094's Avatar
Originally Posted by 99SH
Google Lisle 24680
x10000000
That thing is indispensiable. I loan mine out to people all the time and get it back with the same praise from them on how well it works and how easy it is to use.
Old Feb 9, 2015 | 03:12 AM
Hershey's Avatar
Sounds like theres still air pocket in the coolant system. I took note that you changes your sleeves in the block. What aftermarket sleeve did you go? I'm thinking with open sleeves like Benson or darton sleeves you don't need to run a block guard. I ran block guard before on my turbo integra gsr and it was clogging my coolant system like crazy. Took it out and the car ran fine with no overheating. I would take off that block guard if you have a built block with sleeves from other company already.
Old Feb 9, 2015 | 03:29 AM
staylor725's Avatar
I was thinking the same thing maybe block guard causing over heating, looks like he has stock sleeves bored with dry sleeve pressed in.
Old Feb 9, 2015 | 07:23 AM
Hershey's Avatar
I just now saw that he had a picture load. After looking at the picture. Looks like the block guard is a supertech brand. Same one I use in my integra that gave me tons of over heating issue. I would loose the block guard as the stock sleeve can handle boost good.
Old Feb 9, 2015 | 08:13 AM
Soul Coughing's Avatar
As others have said, bleeding the system correctly is extremely important in guaranteeing you don't over heat the motor; especially when you say you don't have heat in the cabin. Having a look at that block and the block gaurd, I am not surprised though that you may have issues with flow though! The holes drilled into that guard are incredibly small and would be an extremely apparent cause of your issues, especially considering Honda engineered the cooling system to run with an open bore setup.
Old Feb 9, 2015 | 09:13 AM
KaNgArOo's Avatar
I had overheating issues too. Bleed the system like crazy. It's pretty tuff to get the air pockets out of these motors.
