P0420 code and track days
Old Aug 14, 2013 | 08:12 AM
NH_s2k_Guy's Avatar
Default P0420 code and track days
I am running a Vortech V3 with a aftermarket cat (see rest of my setup in my signature) and ever since the cat install, I have been gettin a P0420 check engine light.
Something about the catalytic converter not operating within threshhold, if I remember correctly.
I have an HPDE scheduled for next Monday and I tried asking my tuner and mechanic about it but they aren't available.
The car seems to be running just fine but can I do damage if I run at track speeds with this CEL?
ANY insight would be greatly appreciated as I really want to run this last HPDE before the car goes into hibernation!
Old Aug 14, 2013 | 09:30 AM
Jmays2k's Avatar
I would say yes that you should be fine but I don't have any evidence to prove that you would be ok. I have run on the track many times with cels as long as they aren't engine code specifically then I wouldn't worry about it to much.
Old Aug 14, 2013 | 10:31 AM
Phill24's Avatar
U will be fine do the o2 trick and the code will be gone..u can even take the cat out
Old Aug 14, 2013 | 01:15 PM
GrandMasterKhan's Avatar
Just to be sure you should uninstall your cat and be sure the catalisyt materal hasnt come loose. Mine rotated inside the cansiter and blocked exhaust blow. I ignored the p0420 code and bad things happened under boost as you can imagine.
rlaifatt
Oct 27, 2008 12:43 PM
jamieM
Apr 12, 2007 02:00 PM
Shamu
Dec 22, 2001 07:55 PM
