To pass emissions with EMS
Old Sep 14, 2006 | 08:53 AM
Mirror's Avatar
They still plug in to the OBD but don't require it to pass. I would still go to the emissions place and ask if they require OBD testing.
Old Sep 14, 2006 | 09:23 AM
afwfjustin's Avatar
Originally Posted by synapse,Sep 14 2006, 11:50 AM
BTW you can't turn down boost just with a boost controller. Whatever the rate is of the spring that is in the wastegate will be your floor for boost pressure, you actually have to change out the spring.
This has been covered, but thanks anyway
Old Sep 14, 2006 | 09:24 AM
afwfjustin's Avatar
I'll check on it. I know that they don't do a sniff test on newer model cars with OBD2. After emissions, I get a readout of all the pollutants just by them plugging into the obd2 port.
Old Sep 14, 2006 | 12:47 PM
derek14's Avatar
I plan on pulling my supercharger belt off
that should cover it for me... Emissions is one reason I didnt go EMS...
Old Sep 14, 2006 | 01:00 PM
Mirror's Avatar
will the engine pull in enough air through the SC when it's not spinning?
Old Sep 14, 2006 | 01:06 PM
VeilsideAP1's Avatar
If it were me, I'd ask some local tuners if they know a place that accepts cash payment for emissions testing... read between the lines...
Old Sep 14, 2006 | 01:11 PM
C4SxM5's Avatar
or you can just find a shop that will do it with another S2K and not have to worry about removing anything
Old Sep 14, 2006 | 01:54 PM
ScottyBallistic's Avatar
Both the above are options . And I have practiced both
Not for long , soon they will be pulling the VIN from the ECU
Old Sep 14, 2006 | 02:09 PM
news2kroller's Avatar
how did you get a good tune with-out ems? i want to keep the factory managment but it seems like the only way to get the most out of your car is ems (which seems like the only way, why spend $$$ on a kit that isnt performing to its potential)
Old Sep 14, 2006 | 02:52 PM
Slows2k's Avatar
The time is now. Every new model since the 03 Accord has the Vin encoded to the PCM. You can bet the AP2 cars are the same.
