Pfab log fitment - need help
Hello,
Looking for a little help from the members. I have recently fitted a precision 6262 with a T3 .82a/r vband to a pfab top mount log and the turbo position does not look like the image on their website, or any others in a Google search. Looking for help from someone that has this manifold, or has experience with it. Here are a few images of its position.
I have 5.5" from the surface of the head (at valve cover seam) to the center of the turbo shaft.
Appreciate any help!
Thanks
Jason
Thanks
Jason
R u saying it's clocked wrong? Or u think something is gonna be rubbing?
What exactly are u concerned about?
Post a picture of what's different as well.
I foresee that heated wrap hose running straight through the vband being of concern which is not correctable by clocking tho.
It seems to be mounted out further on the manifold than most that I see online. Positioning it further away from the head and valve cover. Could just be me, looking for additional input from people that have experience with this manifold.
Thanks
Thanks
Yours looks pretty off from mine. I had the same manifold with a hx35 and my compressor housing is close to my valve cover. I'm not sure why yours is like that.
I will say one thing is I had trouble with mine having bolts back off. Even with crush washer, nord-lock washer. I sold this manifold but found out studs with crush washer and nuts worked for my new set up.
Your welcome. Your manifold looks fine. I'll get some picture of mine so you can compare. To me just from your picture, looks like your exhaust turbine looks different. Could just be from the pictures
