Innovate ethanol gauge
Is anyone using the innovate 4 in 1 gauge? PN 3906 with the sensor.
http://www.innovatemotorsports.com/products/ecb1.php
I currently have the aem air fuel gauge and aem boost gauge. I don't want to add another gauge to monitor ethanol content when I start using e85. I came across this gauge and figured it would fit my needs well.
Any input?
Any input?
Update
I bought the gauge and have been having issues with getting the afr to read good 100 percent of the time. They have already sent me one replacement sensor. If I'm cruising around and left off the gas it reads full lean (22.4) until I get back on the throttle. Sometimes when it reads full lean it reads e8 which is an error code. If I restart the car it's fine again. The gauges seems to read fine until this happens. All the other readings( boost, ethanol content, fuel temp) seems to be working with out issue. I'm going to get retuned soon on flex fuel and don't want to let this afr issue be a possible problem. Any suggestions? I might switch back to the aem afr gauge.
Honda-S2000VTec
Nov 24, 2003 04:25 AM
