pics of my bov connection
Old Dec 25, 2006 | 01:37 PM
ericshun's Avatar
Default pics of my bov connection
there were two lines one from the intake manifold, and then the other one from that circular thing on the right corner.
following the intake manifold line, theres this split and one of them goes to the bov.
that same intake manifold line splits up and goes to this box i'm not sure what it is
i think from someones picture it is supposed to be the acv check valve.
is this connected correctly? still having a weird blowoff noise
Old Dec 25, 2006 | 06:05 PM
m R g S r's Avatar
wierd blow off valve noise...or compressor surge? if its like a chu chu chu chu then its compressor surge....which i guess means your BOV isn't connected correctly, OR its broken, OR you have a strong spring in it and it isn't opening......
Any of those three lines to the left of the IAT (it looks like an IAT Sensor) are a direct source of vaccuum...and those will work for the BOV....
Old Dec 25, 2006 | 06:08 PM
m R g S r's Avatar
okay so i re-read...and you say the small diameter line you have T'ed is going DIRECTLY into the intake manifold....if thats the case then it is connected correctly....only other thing I can think of is the diameter of the line isn't large enough, but heres a way to check.
Un bolt the BOV from the charge pipe, Leave the vaccuum line connected and start the car....it SHOULD be open at idle....then if you open the throttle body to releave the vaccuum, the BOV should close....try that and see if it works out!
Old Dec 25, 2006 | 06:29 PM
JDM S2000's Avatar
Banned
what BOV is it?
Old Dec 25, 2006 | 06:40 PM
ericshun's Avatar
[QUOTE=m R g S r,Dec 25 2006, 07:08 PM] okay so i re-read...and you say the small diameter line you have T'ed is going DIRECTLY into the intake manifold....if thats the case then it is connected correctly....only other thing I can think of is the diameter of the line isn't large enough, but heres a way to check.
Old Dec 25, 2006 | 06:43 PM
deathsled's Avatar
a boosted AP1 with no krank vents? tsk tsk tsk
Old Dec 26, 2006 | 05:37 AM
SIIK2NR's Avatar
Old Dec 26, 2006 | 01:30 PM
ericshun's Avatar
if that last picture in my set of pictures is to the ACV via check valve then i think it should be done correctly..is that the ACV in the last pic?
Old Dec 26, 2006 | 05:42 PM
SIIK2NR's Avatar
Yes it is.....
Check your spring tension if it's sounding like a gobbling turkey instead of a normal BOV.
Tim
Old Dec 26, 2006 | 06:16 PM
ericshun's Avatar
Originally Posted by SIIK2NR,Dec 26 2006, 06:42 PM
Yes it is.....
Tim
its not sounding like a gobbling turkey just making a weird whistling and slow blowoff
