pics of my bov connection
Old Dec 27, 2006 | 08:03 PM
ericshun's Avatar
bump..can anyone figure out my whistling problem??
Old Dec 27, 2006 | 09:40 PM
TheCarGuy2021's Avatar
Try using a different vaccum line. That black box is a vaccum canister (it's all hollow inside) that may have something to do with it. Another reason may be that you have a BOV built for high boost applications, and you are not running very high boost with a Comptech (correct me if you aren't at stock boost). I have the Raptor by Turbonetics (1 step below Godzilla) and I have a little bit higher boost from the Vortech, but mine works just fine. He also shouldn't be getting any compressor surge (it's not a turbo) unless his belt is really loose.
What does it sound like? Godzillas are known for their loudness...
Old Dec 28, 2006 | 03:19 PM
John_Z's Avatar
Try running a dedicated line to the bov. If it still whistles it could be an improperly set up bov(too little spring pressure) or a defective unit. Rember, it's supposed to vent at idle and cruising under no-load conditions.
Old Dec 28, 2006 | 03:37 PM
revhi's Avatar
Originally Posted by ericshun,Dec 25 2006, 10:40 PM
when i start the car it is venting at idle and then when i give it gas the bov does close and vents when the throttle is let off. at low rpms like up to 2->3k theres no much whistling noise, but when it gets to higher rpms it whistles and the air seems to escape really slowly
it is the godzilla bov
Um that is normal. Your BOV works fine.
Old Dec 28, 2006 | 07:53 PM
ericshun's Avatar
doesnt sound like your video though. in your in between shifts theres no whistling and when i shift in my car i hear whistling. i dont think you understand the noise i'm hearing.
when i'm cruising at around 70mph in 6th theres this high pitch whistle thats really annoying.
Old Dec 28, 2006 | 07:59 PM
revhi's Avatar
Is your bov used? Mine does that now because the seal is worn. Tighten the spring.
Ek_Jak
Jun 30, 2017 02:39 PM
volcomboy390
Feb 23, 2017 04:53 AM
titoracingfab
Apr 20, 2016 06:50 PM
s2konroids
Jan 25, 2011 06:53 PM
dmarvin3
Jul 17, 2007 10:25 AM
