piston design
Old Jul 17, 2008 | 01:52 PM
ERL_S2000's Avatar
I agree above, something is off.
Old Jul 17, 2008 | 02:32 PM
btstone84's Avatar
Originally Posted by timg,Jul 17 2008, 01:45 PM
I made over 400 whp on 10 psi on my first dyno run with only street tuning. By the last dyno runs, I was at 16 psi peak (10 psi at redline) and 443 whp and 353/363 torque (this is on 91 octane).
you went 10psi to 400whp the 6 more PSI only got you 43 more psi? need new tune, very inefficient
Old Jul 17, 2008 | 02:41 PM
Soul Coughing's Avatar
[QUOTE=btstone84,Jul 17 2008, 05:32 PM] you went 10psi to 400whp the 6 more PSI only got you 43 more psi?
Old Jul 17, 2008 | 05:22 PM
timg's Avatar
You need new eyes, very inefficient
Just kidding. You really should have actually looked at the dyno charts before assuming the tune sucked though.
The 10 psi and 401 whp was near redline because I had a bit of boost creep (didn't really mean to hit 10 psi on my first dyno run- you can see the boost creep in the shape of the torque curve). When I finished tuning, I was still at 10 psi at redline, but I had bumped it to 16 psi in the midrange. I also had an extra 25 hp at redline at the same 10 psi. I would have held it at 16 psi, but the fuel system couldn't supply enough fuel. (I'm basing boost values off the readings of the GM 3 bar MAP that were in the log.)
At 5400 rpm, I gained 140 hp and 135 ft-lb between dyno run 1 and dyno run 19. You're right, my tuning really sucks...
Run 1 and Run 19 (Superflow chassis dyno)
Change in Horsepower and Torque from run 1 to 19
Dynojet run for bragging #'s (and to beat out that dyno shop's highest HP street Honda at the time) This was also on 91 octane pump gas.
Tim
Old Jul 17, 2008 | 05:24 PM
timg's Avatar
Originally Posted by btstone84,Jul 17 2008, 05:41 AM
i have the head gasket and im shootnig for over 600whp.
You'll probably get there with a good tune and an efficient turbo setup. The stock motor has proven to be very capable of high levels of horsepower.
Tim
Old Jul 17, 2008 | 08:16 PM
jzz30's Avatar
[QUOTE=timg,Jul 17 2008, 11:45 AM] That sounds like a weird case.
Turbo2000s2000
Sep 22, 2016 10:55 AM
flipnrr
Oct 30, 2007 05:44 AM
jbotstein1
Feb 26, 2006 09:55 PM
Scorpion
Nov 15, 2005 04:44 AM
pierceman
Feb 8, 2003 02:03 PM
