Pistons, and rods
the only issues with wiseco shelf pistons are people pushing the shelf pins too far. Wiseco specs the shelf pistons with light weight pins only good for around 550hp.
If you get a cp hot it'll break, if you get a wiseco hot.. it just gets hot and nothing happens.
Is there a good piston I can buy that has higher Compression Ratio? I would like to be in the 9-10:1 range. What CR have you guys had the best luck with. I want the ratio to be low enough so that I won'thave to worry about detonation, but high enough to where I can still get good spool time and not have to run a ton of boost.
I am the perfect example of this, ran shelf wisecos at 800 and snapped a wrist pin, gotta go for the beefier wrist pin next time, but i cant agree on the "it gets hot and nothing happens", anything that gets hot enough will fail eventually
Originally Posted by wadzii' timestamp='1352981317' post='22152503
the only issues with wiseco shelf pistons are people pushing the shelf pins too far. Wiseco specs the shelf pistons with light weight pins only good for around 550hp.If you get a cp hot it'll break, if you get a wiseco hot.. it just gets hot and nothing happens.
When benson does my block in feb im doing 11:1
Sent from my DROID RAZR using Tapatalk 2
Originally Posted by passmans2kny' timestamp='1353001691' post='22153145
call wiseco and talk to someone, they will make whatever u want, I will be doing this soon with a 11:1 compression ratio
