Please Help Flooded..
Old Oct 28, 2010 | 06:01 PM
  #41
Fallen's Avatar
So i talked to couple more people and some of them told me the problem can be a timing chain or a headgasket?
Old Oct 28, 2010 | 06:06 PM
  #42
s2000Junky's Avatar
No... I wouldn't think the chain could effect cam timing enough to not even want to start, but ignition timing... yes.
Blown head gasket is a problem, but the engine would still have more then enough compression to start. It will run like lumpy ass but it will start.
Old Oct 28, 2010 | 06:07 PM
  #43
Fallen's Avatar
hmm... What about head gasket? My car does have 109,xxx
Old Oct 28, 2010 | 06:41 PM
  #44
Fallen's Avatar
Sorry didnt see all of your post. So what do you think i should try?
Old Oct 28, 2010 | 06:54 PM
  #45
Fallen's Avatar
Guys here is the link to video thanks
[media]http://www.youtube.com/watch?v=7FBH3DHsmC8 [/media]&feature=player_embedded
Old Oct 28, 2010 | 10:05 PM
  #46
s2000Junky's Avatar
I'm at a loss at this point. I don't know what aftermarket systems you might have in place that could cause this, eliminating the variables such as this would be helpful. Need to figure out if it OEM related or related to your turbo system. I wouldn't think that all 4 injectors would just go bad at the same time and cause this issue, are they aftermarket or OEM? A piggy back unit controlling the injectors could be an issue. Map clamp issue?
Old Oct 29, 2010 | 07:07 AM
  #47
t0m's Avatar
t0m
He said he has stock injectors and an FMU controlling the fuel. That sounds horrible. I sounds like the starter? When mine cranks a lot faster than that (even when I was having fuel issues and not starting) and it has 143,000 miles on it.
Old Oct 29, 2010 | 07:23 AM
  #48
Ultimate Racing's Avatar
Pour a small bit of engine oil in each cylinder and see if that gets it started up.
Darryl
Old Oct 29, 2010 | 10:24 AM
  #49
Fallen's Avatar
I think the starters is still good. We tried jump starting the car with another car. The engine starts up but there is no response from gas and when the rpms drop the engine turns off.
So im thinking if it is the starter the car would still run when jump starting.
Old Oct 29, 2010 | 11:53 AM
  #50
s2000Junky's Avatar
Darryl
What will that do besides foul the plugs and make it even more difficult to start?
