PLM header vs. Comptech vs others?
Old Jun 13, 2011 | 07:43 AM
s4play's Avatar
Default PLM header vs. Comptech vs others?
I'm currently running about 10psi on the SOS kit and deciding if the OEM header is good enough or too restrictive?
Right now we have the OEM header, Berk HFC and a Fuji dual exhaust. I love the sound, no CEL and perfect smooth operation but not sure if the stock header flows well? I'm sure Honda engineers make a pretty good piece so don't want to "degrade" my car with a crappy aftermarket one. I also noticed the stock header has an O2 sensor just before the cat, will I lose this with most aftermarkets?
Is there any particular brand that is better than others or stands out? I need it to be CARB legal.
I had the Comptech before and the quality seems pretty good but how's PLM? Or Berk?
thanks
rick
Old Jun 13, 2011 | 08:12 AM
silverstonejedi's Avatar
I know a couple of peeps who are SC that say the Berk header does well with SC setups.
Old Jun 13, 2011 | 08:22 AM
Deception's Avatar
stick with stock its good for over 400whp.. with an aftermarket you MIGHT gain 5hp but is it really worth $1000?
Old Jun 13, 2011 | 10:22 AM
s2000Junky's Avatar
There is a new header thread in the N/A forum. It translates to SC. It seems as if Toda/J's racing are pretty matched with offering some gains over stock across the entire powerband. The Hyatech even more so. But I agree, unless you want to spend $1000+ for 5-10whp, I don’t think it’s worth it. The stock header is pretty dang good to 400whp. Don’t assume the rest of your exhaust is going to be matched to exude the most from your new header either. Plan on investing in the whole system or don’t bother.
Old Jun 13, 2011 | 10:45 AM
Drkphnx's Avatar
Toda header here, with 70mm invidia test pipe to T1R70r em dual sparrow. LOVE it
CTSC non AC @300rwhp, soon to be about 400
Old Jun 13, 2011 | 10:47 AM
Torque Obsessed's Avatar
Exactly. The OEM header is surprisingly good and most aftermarket ones don't seem to make gains while NA. With FI, a few become clearly better, but as s2000Junky said, it's usually 5-10whp. You have to spend an awful lot of money to get meaningful gains from exhaust mods on this car.
Sometimes I daydream about doing a header, 70mmHFC and custom 70mm exhaust, more to reduce boost pressure due to better flow than to make power. But I'll probably never do it.
I had your exact setup (Berk + Fuji) and it was perfect when I was Greddy'd, but became rather loud once I went SOS. I'm glad you like it! Sounds big and mean when you hit VTEC, doesn't it?
Old Jun 13, 2011 | 12:40 PM
06S2k07Si's Avatar
J's vs stock:
https://www.s2ki.com/s2000/topic/873...esults-are-in/
J's vs Hytech:
https://www.s2ki.com/s2000/index.php...f=142&t=817368
Brian
Old Jun 14, 2011 | 03:21 AM
gettin it's Avatar
Just got my car back up and running. As soon as Mase returns, ill be getting it retuned. Im currently at 11.5 psi and i made on his dyno 380whp. Vortech kit. I just installed the PLM header and testpipe. Ill keep you updated.
Old Jun 14, 2011 | 07:36 AM
MasterForce's Avatar
please do! im wanting to know if PLM is the way to go or i should save for a js racing one
Old Jun 19, 2011 | 07:15 AM
gettin it's Avatar
Update, Mase dynoed my car this past friday. I installed the PLM Header and Testpipe. Nothing changed at all. My power and tq stayed the same. Nothing. So i have a friend who is selling his Toda header, im going to try that to see if it makes a difference. Just thought ill fill you guys in.
08s2000CRbackinblack
71
Dec 14, 2011 02:52 PM
s2konroids
Feb 7, 2010 01:19 PM
midnightmethane
Oct 23, 2006 03:57 PM
SaltyDog
Apr 4, 2006 09:43 PM
S2000_Europe
Jul 14, 2003 12:46 PM
