Plm Twinscroll t3?also vtec killer with FI?
Old Apr 11, 2014 | 05:58 PM
esean93's Avatar
Default Plm Twinscroll t3?also vtec killer with FI?
Sup fellas, im all motor for now. Few question for you,any input is appreciated.
What do you guys think about the Plm t3 twinscroll manifold? Its like 700 with the downpipe. What is the flow limitation with a t3 twinscroll setup? At what power level would it be more ideal to switch to a t4 twinscroll?any recommendations on a turbo to achieve 500-600 with decent spool.
While im all motor, i really wanted to try out vtec killer cams. Also steady oil pressure will be ideal for track driving. I know it makes it easier to tune but whats your opinion on adding a turbo setup later down the road with a vtec killer cam.
thanks in advance.
Old Apr 11, 2014 | 06:52 PM
riceball777's Avatar
It's junk. Don't buy it.
If you want twin scroll go with the full race t4 twin scroll manifold or the full race efr t4 twin scroll internal waste gate setup.
Old Apr 11, 2014 | 07:08 PM
esean93's Avatar
Horrible welds or just cheap piping?
I want twinscroll for optimum spool.
how do you like you single t3?i see you spool at 5k which is late imo for a f22 but decent for a f20 i imagine.
Old Apr 11, 2014 | 07:38 PM
bobbyrandolph440's Avatar
thanks in advance.
Assuming you're not wanting to go too much out of your price range you should look into the sheepy built twin scroll and your power goal can be had very easy on t3 mani
Sent from my VS870 4G using Tapatalk 2
Old Apr 12, 2014 | 02:19 AM
camuman's Avatar
Problem with divided is you need flow. Doing t3 limits that. Go t4 or do t3 open with a gt30 sized turbo.
Old Apr 13, 2014 | 06:54 AM
esean93's Avatar
thanks in advance.
Ive heard good thing about the sheepy manifold.
Do you mean t3 undivided?how fast would it spool?
I would prefer atleast 50% peak pressure around 4k with my f22
Old Apr 13, 2014 | 06:56 AM
esean93's Avatar
T4 twin is definitely the ideal setup for a high hp setup. Really like the full race t4 twin but pretty expensive in my opinion.
esean93's Avatar
I need input on toda vtec killers and FI!
Old Apr 13, 2014 | 07:08 AM
Originally Posted by bobbyrandolph440' timestamp='1397273919' post='23108847
[quote name='esean93' timestamp='1397267893' post='23108744']
thanks in advance.
[/quote]
Yes t3 undivided but the spool will be really off your turbo a gtx30r will be your best turbo for your power and spool goal but they cost a good bit
I have a t3 gt35r. .63 exhaust on my 1.8 gsr swap civic and it's full boost by 4200 but it would choke up on the big end on f20/22 I would think
Old Apr 13, 2014 | 10:17 AM
ScorpionT's Avatar
On the F series a divided T3 would be a bit of a restriction. I would go T3 or divided T4. They will spool fairly similarly with the T4 having more potential for power but it will also be more complex and expensive. Plenty of good options to pick from. FBM, FR, Sheepy...
Is 500-600 your maximum goal, or are you planning to have it tuned for that regularly with room for more if needed?
