plug and play MAP sensors now available
Old Nov 24, 2008 | 04:34 PM
ScienceofSpeed's Avatar
Former Sponsor
Default plug and play MAP sensors now available
No more hacking up the factory wire harness to install an upgraded MAP sensor!
The standard Honda MAP sensor is capable of measuring up to 11 PSI of manifold pressure. Any cars above 11 PSI must upgrade the MAP sensor. The ScienceofSpeed 3-bar MAP sensor is a direct replacement for the factory MAP sensor allowing for accurate intake pressure measurement of up to 28 lbs.
This sensor is unique compared to other sensors in that it uses the factory MAP sensor plug and fits into the factory location. No cutting or other modifications of the factory wire harness is required.
The lab grade sensor transducer provides a reliable linear voltage response from vacuum to 28 lbs of pressure. This sensor allows good resolution for vacuum conditions allowing good idle & driveability.
This sensor is intended to be used with a stand-alone engine management system like the AEM EMS or Hondata K-Pro.
http://www.scienceofspeed.com/products/eng...eed/MAP_Sensor/
Note that 2000-05 and 2006-08 MAP sensors are different. We have in stock both models.
Cheers,
-- Chris
Old Nov 24, 2008 | 04:57 PM
berlinas2k2's Avatar
Looks great!
Send me one to test
Old Nov 24, 2008 | 05:36 PM
jwa4378's Avatar
Hondata has had one that was PNP... its a 4 BAR MAP.
http://www.horsepowerfreaks.com/partdetail...ors/4_Bar/13828
Yours still needs to be calibrated manually in the EMS, right?
John
Old Nov 25, 2008 | 03:53 PM
Former Sponsor
This MAP is 3 BAR which allows a pressure range of vacuum to 28 psi. The 3 BAR MAP compared to a 4 BAR will offer much better resolution for cars with 28 psi or less peak manifold pressure (which would be about 99.99% of turbo/supercharged S2000s.
We include a scalar table for the MAP - easy to use.
Cheers,
-- Chris
Old Nov 25, 2008 | 04:13 PM
SPECIAL-OPS-S2K's Avatar
awesome
jwa4378's Avatar
ooooo... If you include the calibration table values, its tempting!
John
Old Nov 25, 2008 | 04:54 PM
dsddcd's Avatar
You have had this on your site for at least 6 months I have been telling everyone about it. So for all the avertising do I get one for free? Do a search you will find a bunch of entries.
Old Nov 25, 2008 | 05:59 PM
9kFever's Avatar
offered in any other colors? The one thing i loved about the hondata was the sleeper status.
Old Nov 26, 2008 | 02:33 PM
Former Sponsor
Sorry, red is the only color we plan to offer. It does not stick out in the engine bay in my opinion.
Cheers,
-- Chris
Old Nov 26, 2008 | 02:48 PM
jbell's Avatar
Banned
sleeper is called "don't pop your hood" where i'm from.
