PLX dm-100 users chime in
Old Sep 12, 2012 | 12:34 PM
s2k_Zyke's Avatar
Default PLX dm-100 users chime in
for those of you using the plx multi gauge, what all do i need to be able to see boost, intake temp, A/F ratio, and oil pressure at one time on this one gauge? each seperate module for the things i want to see? wideband o2 sensor? any info on how you guys are running your would be great.
Old Sep 12, 2012 | 01:08 PM
wy2slow_z's Avatar
well IMO the best way is 2 gauges. put boost/vac on a dm-6 gauge and the rest using a 4 parameter display on the dm-100 gauge. u can only see 4 at a time on the dm100.... boost/vac/af/oil pressure/iat=5
Old Sep 13, 2012 | 05:58 PM
s2guru's Avatar
no need for that.
I have the dm-200 in the setting you can set as default to see 4 item in the LCD ( my case: boost, oil press ) i will get A/f soon, make sure you set you letters color to White, so you can see them during the day.
Old Sep 13, 2012 | 06:28 PM
wy2slow_z's Avatar
i realize that. the OP listed 5 parameters though. all you really need is a/f, boost and oil pressure.
Old Sep 13, 2012 | 07:03 PM
s2k_Zyke's Avatar
i figured i would just use the dm-100 to see boost, iat, a/f, oil pressure for the 4 parameter view and figure out how to mount it flush above the start button
Old Sep 13, 2012 | 07:05 PM
s2k_Zyke's Avatar
Originally Posted by s2guru
no need for that.
where are you mounting the module boxes?
Old Sep 13, 2012 | 07:09 PM
s2guru's Avatar
Originally Posted by s2k_Zyke
Originally Posted by s2guru' timestamp='1347587928' post='22010480
[quote name='wy2slow_z' timestamp='1347484131' post='22007361']
no need for that.
[/quote]
underneath the drivers seat.
Old Sep 13, 2012 | 07:17 PM
s2k_Zyke's Avatar
Originally Posted by s2k_Zyke' timestamp='1347591930' post='22010609
[quote name='s2guru' timestamp='1347587928' post='22010480']
no need for that.
[/quote]
[/quote]
wow cant believe i forgot about that as a spot lol, i might have to copy you now
Old Sep 13, 2012 | 07:27 PM
Forcedbird's Avatar
I mounted 4 modules under the drivers side dash.
Old Sep 13, 2012 | 08:20 PM
s2k_Zyke's Avatar
Pic?
