Possible Problem?!?
Hey guys I have a slight problem. I was pulling my coils and plugs out to just do a routine inspection when I noticed one of my coils and the plug tube were covered in rust. I cannot figure out how I'm getting water inside the spark plug tube. The car is not running bad, or making any weird noises in any way. I pulled the valve cover off and there is no water/ coolant in the oil. There was some kind of gel around the seal for the spark plug tubes that smelled like E-85. I am running E-85 on my car and I know that the fuel starts to mix with oil, but the oil has only been in the car for about 500 miles. Any way I took a ton of pictures, maybe someone else has had this happen to them. Any help will be greatly appreciated!! :tipwink:
Here you can see the gel substance around the coil tube seal. http://i967.photobucket.com/albums/a...-23-52_862.jpg http://i967.photobucket.com/albums/a...-24-04_343.jpg http://i967.photobucket.com/albums/a...3-24-11_47.jpg Here you can kinda see the rust all along the wall of the tubes. Mostly in cylinder #3, but a little in cylinder #4. http://i967.photobucket.com/albums/a...3-24-19_63.jpg http://i967.photobucket.com/albums/a...-24-55_298.jpg http://i967.photobucket.com/albums/a...-25-11_198.jpg Here is a shot of all of the coils in cylinder order. Starting from the left Cylinders #4, #3, #2, & #1. http://i967.photobucket.com/albums/a...-25-50_620.jpg Same order on the plugs. Notice how cylinder #3 has rust at the base of the porcelain part of the plug. http://i967.photobucket.com/albums/a...-26-10_630.jpg Same order again. http://i967.photobucket.com/albums/a...-26-39_869.jpg http://i967.photobucket.com/albums/a...3-26-50_49.jpg http://i967.photobucket.com/albums/a...3-26-55_10.jpg http://i967.photobucket.com/albums/a...-26-59_442.jpg http://i967.photobucket.com/albums/a...-27-08_937.jpg Removed the valve cover and inspected for any signs of a blown head gasket or other damage. http://i967.photobucket.com/albums/a...-43-29_227.jpg http://i967.photobucket.com/albums/a...-43-34_799.jpg http://i967.photobucket.com/albums/a...-43-52_396.jpg I also have a bore scope camera that allows me to look down into the cylinders. When I looked down into the cylinders there didn't seem to be any cylinder scoring, or any head gasket damage. Can anyone tell me why this happened?? |
Was that plug loose. I see this all the time on fords with loose plugs.
Originally Posted by japhethwar
(Post 21587864)
The seal around the coils is probably trashed?
Condensation perhaps? Consider that the rust is pretty far up the tube, I don't expect it was that full of water but condensation on the walls would certainly give that situation. did you tighten down your coils properly? That said, it almost looks like valve train parts have water in em too by those pics..... I hope I'm just not seeing it clearly. |
do you let the car sit extended periods of time?
Originally Posted by 05TurboS2k
(Post 21588427)
Condensation perhaps? Consider that the rust is pretty far up the tube, I don't expect it was that full of water but condensation on the walls would certainly give that situation. did you tighten down your coils properly? That said, it almost looks like valve train parts have water in em too by those pics..... I hope I'm just not seeing it clearly. The coils were properly tightened, but I am not 100% positive the seals on the coils are doing their job. (Original coils with 108k miles) The spark plug tube did not have any standing water in it whatsoever. As far as the valve train having water on it, that must just be an illusion made by the poor quality pictures. I did not see any signs of moisture on anything internally.
Originally Posted by b.r.i.a.n.
(Post 21588454)
Originally Posted by 9krevvin
(Post 21588517)
Yes I do. I have been thinking that that could play a role in why this happened, but I just don't really know why.
(Post 21588655)
E85 is hygroscopic just like brake fluid, I would have your injectors tested as well, a few people have rusted sets closed. There is a good writeup about this a few pages back, I will try to dig it up. |
(Post 21588655)
(Post 21588517)
(Post 21588454)
The humidity you have in Houston would be the problem especially when you run it hot and then a cold night sets in. I'd have a good look at the seals, you can use a few different things to mark the seals and test if they're sealing, they make a crayon/chalk for that used in setting gears in a rear diff, it's bright yellow. |
