https://cimg9.ibsrv.net/gimg/www.s2k...ea37af09ee.jpg
https://cimg1.ibsrv.net/gimg/www.s2k...02672d38cf.jpg https://cimg2.ibsrv.net/gimg/www.s2k...1ce93732e2.jpg https://cimg3.ibsrv.net/gimg/www.s2k...fc86dcf3f4.jpg Bringing this back from the dead. I have recently replaced all my valve cover gaskets, spark plugs, and coil packs due to a really bad leak in cylinder 2 and 3 but low and behold only after 1 month it is leaking again. Upon closer inspection this time I noticed all the tubes are rusting to shit along the walls... All four cylinders. For cylinder 2, I believe the rust has gone through the wall causing oil to leak into the tube. I may need to buy a whole new cylinder head due to this. Also, I am on e85. I think this is the cause of the rusting as e85 tends to create moisture in the cylinder head. Did anybody hear reach a solution or figure out what the problem was? Is there even a way to replace the metal tubes? Or is that a part of the cylinder head? |
Old thread! Well to me, in the OP case, the Tube seals in pics look twisted, not seated properly. If you replaced them and jammed the valve cover back on without any kind of lubrication to allow them to slip over the tubes, I could see this happening. That aside. It looks to me like you maybe had water pooled up on top of the valve cover and eventually leaked down past the coils and into the tubes. Just enough to keep moisture in there and rust. The engine/cylinders themselves are probably totally fine. The spark plugs look normal/w no signs of coolant burning or other contamination. .
The metal tubes should slip out/replaceable. |
Originally Posted by s2000Junky
(Post 24963447)
Kind of odd that Honda would make those out of regular steel that can rust, instead of stainless.
^^^it is odd. Every tube has some rust, and rust only formed along the middle of the pipe about 1" in height consistently on all four. some worse than others. All the coilpacks were covered in rust when pulled. Mind you these were brand new coilpacks put in about 1 month ago.
Originally Posted by Mijae007
(Post 24963869)
Nothing to do with moisture in fuel. The combustion chamber is sealed off from the rest of engine, and those tubes, or else you wouldn't have compression. Any moisture from fuel goes out exhaust.
What sort of hood do you have? Letting rain onto top of engine? |
Okay, so this weekend I took the VC off again. Luckily its a leak due to a poorly installed tube seal in cyl 2 causing surface rust to accumulate on the inside of the tubes. It didnt rust through the tubes like i thought. I used rust remover/sealant on the insides of the tubes and replaced all the gaskets. This time being SUPER careful seating the tube seals around the tubes.
I'm running a spoon style vented hood. But i live in socal and hardly ever see rain. Car wash maybe once every 3 months. Multiple people agreed its because of E85. The moisture was coming from a leak in the tube seal (from the head). It was letting oil into the tubes (mixed with e85 fumes) which attracts water. This is why a lot of parts in the fuel and oil system corrode. If running E85, I would recommend oil changes be done much more regularly. I would say every 2k miles. And use E85 fuel stabilizer if you're going to leave it parked for long periods of time between drives. I also reintroduced vacuum to my engine by reinstalling my PCV and connecting the line between the VC and intake manifold. I installed the Balladesports vented oil cap to route another vacuum line from my VC to my catch can. Hopefully this improves the engine's ability to draw out any fuel vapor and moisture caused by it in the engine. I remember a couple times under the oil cap the oil residue looked tannish like it was contaminated with water. My thinking is having the two ports alone going to the catch can with the PCV removed is enough to vent and keep pressure from building up in the engine but was poor at drawing out fuel vapor. At least with the vacuum created by the intake manifold reconnected to the VC it should help suck out the vapors better. :ponder: https://cimg5.ibsrv.net/gimg/www.s2k...ad4d005d03.jpg https://cimg8.ibsrv.net/gimg/www.s2k...ca05f9b26e.jpg |
Those many people that told you your rust problem was caused by an oil leak are wrong.
First of all, you didn't find any oil in the tube, just rust. If it was moisture laden oil, there would still be some oil. More importantly, oil prevents rust. Even if there is a bit more moisture in it than usual. Even if there were a lot more moisture than usual. Which makes more sense: water from car washes and occasional rain went through vented hood to top of engine, where it dripped down into tube, and caused rust OR Oil leaked past tube seal into tube, bringing excess moisture with it, then somehow the oil evaporated but not the water, leaving the water to cause rust. One of these theories requires violating laws of physics, the other just requires water we already know was on top of engine on more than one occasion to have leaked past one of the coil pack seals. |
Originally Posted by Car Analogy
(Post 24965434)
First of all, you didn't find any oil in the tube, just rust. If it was moisture laden oil, there would still be some oil. More importantly, oil prevents rust. Even if there is a bit more moisture in it than usual. Even if there were a lot more moisture than usual. Which makes more sense: water from car washes and occasional rain went through vented hood to top of engine, where it dripped down into tube, and caused rust OR Oil leaked past tube seal into tube, bringing excess moisture with it, then somehow the oil evaporated but not the water, leaving the water to cause rust. One of these theories requires violating laws of physics, the other just requires water we already know was on top of engine on more than one occasion to have leaked past one of the coil pack seals. Now for the rust issue, rust was found in all four tubes. Rust accumulation was forming only inside the tubes about midway down the tube about 1.5-2" wide. The pictures above were poorly taken and I wasn't able to really capture the rust build up. It was pretty bad. The rust accumulated to a point where the rust build up was protruding from the tube walls getting all over the coil packs. Luckily it didn't rust through the tubes as I first anticipated. It wasnt just rust powder, it was hard and jagged when you run you fingers over it. As to why rust was building up i have no clue. I can only assume it has something to do with my use of E85 full time (since I never had this issue on pump gas for 50k miles). FYI, i've been on only E85 for the past 3-4 years. My theory is E85 attracts more moisture thus the fuel vapors in the cylinder head is attracting water doing one of two things: contaminating the oil and causing water to build up and cause rust inside the tube seals. In addition, the way i had my oil catch can set up probably wasn't helping either. I removed my PCV and ran two lines from my VC to the catch can. This setup will push the vapors out only when positive pressure is built up in the cylinder head. Vacuum is no longer present since the PCV was removed and the line connecting the VC to the intake manifold was removed and ports capped. My new catch can setup incorporates a balladesports oil cap with a port to run to the catch can. I reinstalled the oem PCV valve system. So now, vacuum is reintroduced to my engine. I'm hoping this will help draw out any vapors preventing water from accumulating in the head...we'll see only time will tell. |
